Question about BenQ FP71G 17" LCD Monitor
INVERTER POWER CARD
Not too sure where in the U.S to get replacement transistors on this board. Are there any compatible transistors that can be used? Any ideas would be appreciated.
Thanks.
  • 89 Answers
You did not specify the transistor. But this site may help. You can download a quickcross reference software that will give you the replacement parts that you need.
http://www.nteinc.com/
Posted on Sep 15, 2008
Hi when i turn on my 47ln5700 flashes for a second and then goes black. I have sound and see images with flash light. I am not sure if its the led power board or some leds in the led pannel gone bad.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 11, 2017 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
Hi I have a VIZIO E550i-B2 the TV has no pictures not sure if it has backlight but it does have Audio the only way to see picture is to shine a flashlight on it.
Feb 18, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
How do I fix backlight problem on JVC LT32D-500 TV. I want to know if it is perhaps a common problem with this model and it it is FET or transistor related.
Oct 06, 2015 | JVC Televison & Video
When I turn my TV on there is sound, but, the picture vanishes after a couple of seconds. Why?
The backlight inverter is what powers the screen to "light up." You will need to check your power supply for the proper voltages going to the backlight inverter. If those all check out ok, then you need to replace your inverter to get your image back. You can find a new inverter by searching "inverter + model number of your tv.
Please rate if this helped :)
Apr 04, 2011 | LG Televison & Video
No video,screen is dark,there is audio
Hi doubles,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 24, 2011 | LG 42PJ350 42 in. TV
Needed a backligth inverter master slave for viewsonic n5230p
An inverter board is an electronic circuit which boosts a low voltage DC current in to high voltage. It's used to power a CCFL tube in he television, which enables the backlight. The inverter, is composed of a MOSFET transistor, acting as a switch, an a coil, which boosts the voltage. The common high voltage output of the inverter board is around 800V.
If your inverter board has gone bad, you could replace the transistor and the coil in the board. This method is the cheapest option, but involves a lot of soldering and time. I encourage you to replace the whole inverter circuit, which is far easier, and not so much expensive.
You will have to take apart the television. Unplug the TV from the power outlet-wait around 8 hours to give time to the capacitor to discharge. Unscrew all the bolts of the back panel, and then, with a plastic tool-like a credit card- pull the back of the screen. After that, you will be able to see the circuit board of the TV. Then unplug the BUS cable and every CCFL tube connectors carefully-they are easily identified with a pink and a white cable. Afterwards, unscrew the fixing bolts of the board, and change it for the new one. You can buy a new one from ebay-the inverter is integrate with the power supply:
http://cgi.ebay.com/VIEWSONIC-9OC4100200-POWER-SUPPLY-FSP410-5F01-N5230P-/260574190024?pt=LH_DefaultDomain_0&hash=item3cab6e99c8#ht_2463wt_907
All you have to do now, is to reverse your steps. Connect each CCFL tube, put the back of the television on, screw the bolts and you are done.
Feb 21, 2011 | ViewSonic N5230p 52 in. LCD TV
The backlight inverter board .what can aproblem do?
You will have to take apart the television. Unplug the TV from the power outlet-wait around 8 hours to give time to the capacitor to discharge. Unscrew all the bolts of the back panel, and then, with a plastic tool-like a credit card- pull the back of the screen. After that, you will be able to see the circuit board of the TV. Localize the inverter board, it should be identical to this:
http://thumbs1.ebaystatic.com/m/mYnvyfIEorz5TT9qxKTuKzw/140.jpg
Then unplug the BUS cable and every CCFL tube connectors carefully-they are easily identified with a pink and a white cable. Afterwards, unscrew the fixing bolts of the board, and change it for the new one. You can buy a new one from ebay:
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=32AV502R+inverter&_sacat=See-All-Categories
Feb 13, 2011 | Toshiba 32AV502R LCD TV
My LGFlatron W2234S won't come on and instread the power light just flashes. Can you tell me what to do?
the blinking light of the power led means that the start voltage was not working properly, if you are a trained tech you can repair this monitor, but if you are a simple user it's dangerous, there is high voltage inside. cause of blinking light :
  1. puffed capacitor on the power supply
  2. broken FBT on the inverter board
  3. broken transistor on the inverter board
solution:
  1. replace or repair the power board
  2. replace or repair the inverter
Dec 21, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
RCA F20632SE 20" TV
Jun 01, 2017 | RCA F20632SE 20" TV
BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Feb 16, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
66 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
