Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
GE Harmony beeping
Thanks . I did the reset and checked the wire. Did a load of wash, Started Dryer, used power button to power off Washer. Washer turned on and went to My cycles screen after the dryer was running for about 10 minutes. Powered off and came back on by itself in 15 minuites to my cycles screen. Also changed touch pad and did not solve the problem. any ideas? Thanks again for your time.
  • Bill816 Sep 14, 2008
    Ran diagnostics, Said Keypanel Membrane problem. Is this the Panel where on, off , help buttons are?
  • 725 Answers
Yes, the control sensed that a key was pressed for longer then 30 sec... Check wire connection and or replace keypanel membrane
Posted on Sep 15, 2008
Son Threw in a VERY Wet Baseball Uniform - Dryer Now Not Working
ok check the fuse inside the unit! that is attached in the wire you can see the fuse there! if blown replace a new one! then observe the unit!
Oct 03, 2007 | GE Profile Harmony DPGT750EC Electric...
Have GE harmony profile dryer about six years old. Interior light goes on but no other indication of power. Have checked cord, fuses and vent. Any suggestions appreciated. Hal Dresner
These dryer have a re-settable thermal limit mounted on the heater. With any luck that is all you need to do is clean up the fluff in the dryer and reset the limit. Here is the service manual
Nov 29, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Neither my washer or dryer has any power on our electric stackabl
IT IS GOOD THAT YOU STARTED WITH THE HOUSE ELECTRICAL. I WOULD NOW CHECK THE POWER AT THE RECEPTACLE AND THEN TAKE THE COVER OFF THE BACK OF THE MACHINE WHERE THE CORD CONNECTS TO SEE IF MAYBE A WIRE IS BURNT OFF. I HAVE SEEN THIS TOO MANY TIMES TO PASS CHECKING THIS.
Jan 26, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
GE Harmony Washer Beeping
first I would to a hard reset unplug washer and dryer for 30 sec then plug back in... also check the wire that connects the washer and dryer ....if this don't wark let me know I can tell you how to get the error codes out of it... let me know
Sep 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washer leaks small amount. DIY fix: check hoses and ???
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Apr 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer Problems
I have the same problem with my GE washer (GJXRP080B2WW). We started the washer before going out and when we came back home. The cycle finished and the cloths were clean but all wet! I then tried again and it did fill water and drain but didn't agitate or spin. I checked the lid switcher, the timer and the agitator which are fine. However, the motor belt doesn't move and it seems the motor doesn't work when power was on. There are a lot of wires connected to the motor and I don't know which one to check to be sure power goes to the motor. Could you please help me? Thanks.
BTW, I didn't find any Reset button or the start capacity...
Dec 18, 2007 | GE WJRR4170E Top Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
270 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
