Question about IBM ThinkPad 600E 2645 Notebook
Ibm 600e i cant get my laptop to boot. when i start it up an error code for the date and time comes up, i reset the time and then this screen that is green with a white border with a circle with the word off under it and a arrow pointing to a straight line with the word on under it. i dont know what this is and i cant get past it. please help!
  • 1 more comment
  • loamin keita
    loamin keita Sep 15, 2008
    how can i remove my power-on password
  • alancuth Sep 19, 2008
    Hi i had exactly the same problem as you and after replacing my cmos battery the problem cleared, if you search for it there is plenty of info on this site to tell you how to replace the cmos battery
  • stephenmahon Sep 19, 2008
    when i turn it on goes to error
I had exactly the same problem and once i replaced my cmos battery it cleared the problem.
you can find lots of good instructions on here to tell you how to replace the cmos battery
Posted on Sep 19, 2008
Error message 00173,00163 will not boot corrctly
These errors are system options not set, and time/date not set (if I recall correctly off the top of my head)
Basically, you need to replace the CMOS battery.
I would order one online from a place like ( a link for YOUR battery is here... )
It will cost a lot of money though...almost $10 ! And there will be shipping on top of that, and the battery weighs almost a whole ounce!
If you can maybe second mortgage your house so that you can afford these hefty costs, the installation is almost as hard as the price is high.
Fear not though, installation instructions should come with the battery (which hides in the RAM compartment as I recall).
Once the battery is replaced, set the system options and the time/date, and you should never see that error again!
Jun 27, 2011 | IBM ThinkPad 600E 2645 Notebook
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
It brings up time date reset then acts like it wants to boot up but then brings a off on screen and i cant get passed it
You need a new rtc or cmos battery turn the laptop over and look on the back it shows 2 small keyboards by 2 screws remove them turn the laptop back over and at the bottom of the keyboard either corner use a small screw driver to lift the keyboard out the battery is just above the touch pad unplug it and plug in new one reinstall keyboard boot up it will say same thing go into bios and set time and date save changes and reboot
Jul 16, 2009 | IBM ThinkPad 600E 2645 Notebook
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Ibm think pad 600e
Do a search for memtest86.iso. Burn this image to a cd and reboot your computer. When your computer reboots it should begin checking your memory for errors. If you still have problems it might be your hard drive.
Feb 13, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from
Symptom or error FRU or action, in
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
Time and date were not set.
1. Set time and date.
2. System board.
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Error codes for ibm thinkpad 600E
Your bios battery needs replacing
Hope that fixes it for you? :)
Jan 06, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
