Question about Microwave Ovens
How to fix GE microwave door latch - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
My microwave just work about 10 second then the breaker turn off and no heat. Please, tell me what happened?
Posted on Nov 20, 2010
3 Suggested Answers
SOURCE: Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 27, 2008
Fix my ge spacemaker microwave door from wiggling at the door hinges (not the latches)?
http://youtu.be/nIdT4kS3noY This link will show you how to gain access to the problem. Sounds like a lose screw or two
Jan 03, 2015 | GE Microwave Ovens
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
Pushed in spring loaded latch on the microwave. Need to pull it back out. Spring is not broke.
No, you don't have a new problem to fix, and consider yourself and anyone else that uses that microwave lucky.
Depending on where that crack is you need to know that the screen like structor in the door is actually a choke to stop and microwave energy from escaping, including anything around it. They are designed to stop any stray microwave energy from leaving the microwave. This could harm you so if it is anyware near that door choke, if I were you I would order another door. The same goes for the gasket around the inside of the door it to is a choke.
You are also causing yourself some potential danger because the door must never be circumvented to keep the light on or off because if you should accidently start the microwave then you will have problems.
Apr 09, 2014 | GE SpaceMaker Microwave Ovens
I have a GE Spacemaker (JVM1631). The door latching mechanism has failed and will not stay closed causing the the microwave to not function. Do you have any troubleshooting suggestions?
Hi, normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
The best place to order GE parts is Tritronics.
Jan 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I'm trying to replace the lower latch on my ge microwave and don't know if I have to remove the door to disassemble it.
yes. in most cases you will need to take the internal ceramic wall apart form the door to show a small latch that needs to be unscrewed before you can continue.
Jun 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Dec 24, 2008 | GE Advantium 120 Convection/Microwave Oven
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1640GA does not heat, the control is working but when you put the time and start its not working.
The latch on the door of my microwave did not make a connection with the sensor inside.  The GE mechanic fixed this problem by slightly pushing the door upwards (with simple manual force).  That's it. It works fine now.
Aug 20, 2008 | Microwave Ovens
Microwave Ovens Logo
751 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
