Question about Cuisinart DCC-1200 Coffee Maker
Switch doesn't work - can't get it to brew anything
The coffee maker just stopped working -  the clock still works but it won't brew even when on auto timed mode - is there something wrong with the switch or is it something else?
  • Anonymous Oct 14, 2008
    we've owned our cuisinart dcc-1200 coffee maker for less than 1 year. up until just recently, it had worked perfectly. then it's reliability faltered. it seems to be a switch (on/off) issue. we can no longer program auto brew or brew. clock, self-clean, and other functions seem to be working normally. we unplugged it, reset it, cleaned it. it once again worked well…for about 4 days, then the previous problems began occurring again. if we reset it, it would sometimes function normally. it's been about 3 weeks since the problem started. i couldn't locate our receipt, so, we've purchased another coffee maker. we preferred the cuisinart, and would still like to know if anyone has had similar problems, and if they've found a fix.
  • Oliver07 Nov 18, 2008
    I've had my cuisinart for 2 years. The past 6 months it has leaked a little on the counter, but brewed fine. Now the led readout flashes between the incorrect time and H:05, H:06, etc. Unplugging it hasn't resolved the issue. We've been without coffee here for over a week and will need to go shopping for a new coffeemaker. I'm not sure I'd get another Cuisinart.
    Problem Solver:
  • 9 Answers
Try unpluging for a few minutes . If that doesnt work try moving to a diffrent outlet . If that still doesnt work . It is time to get a new coffee maker or to call them and get it replaced under warrenty .
This is a known problem with this brand , we have been through 5 of them for the same thing .
It could be caused from anything such as wear (depending on how often you brew) to a power surge that went through your line or even a failure ...
Posted on Sep 16, 2008
Cuisinart dgb900bc. Set timer to brew at 5 45. Have for many years. Last two nights at 5 45 clock goes to 12 00 AM. Does not come on automatically. Turn on manually and brews coffee as great as usual....
I would assume that the chip/timer unit has failed in the unit. Not sure you want to try to disassemble the coffee maker to get at it. Have you tried reversing the a.m. to p.m. (thus the clock would read 5:45 p.m. at 5:45 a.m.) settings and seeing if the machine would brew the coffee normally? (although I seriously doubt this will work, but...)
Jun 21, 2014 | Coffee Makers & Espresso Machines
Power switch doesn't work.
The handle is not making full contact and it will not signal the next phase to start.
Jan 28, 2013 | Keurig B70 Coffee Maker
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee starts to brew and then stops
You could turn it off, unplug it ( is it plugged into a GFI outlet?) empty it of water and clean every part that you can get off it thoroughly. then dry it carefully and then plugging it back in and just try running water through it with a filter in place. This is just a simple reset. (Even coffee pots are computerized now!)If this does not change anything,
I would clean this pot, put it back in the box and take it back to the store where I purchased it, along with the receipt or credit card receipt. I would not take "no" for an answer. You should not be having these problems after ten uses. Let me know how it works out.
Thank You Your rating is always appreciated.
Aug 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
335 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
