Question about Impact 3/4" Dr. Heavy - Duty Air Wrench
I need a schmatic for my husky 1/2" airtool Model H4103
I receintly bought a used air tools that is locked up. I disassembled it to see possible worn out parts. I was just dirty. I cleaned it up and now need to manual to put it back together. Thanks Rick
    Problem Solver:
  • 17 Answers
Try this website they have user manuels
Posted on Dec 12, 2008
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    Ingersollrand model 259 no power?
    Loss of power in an impact wrench can have many causes (worn/broken impact mechanism, worn motor parts, dirty motor, etc.). It will need to be disassembled and serviced.
    Aug 11, 2014 | Ingersoll Rand Ir 259 3/4" Dr Impact...
    Is it normal for oil to spray out of the front of the Husky 1/2 impact wrench?
    Yes. Every air tool has an exhaust. On impact wrenches this is usually on the front. Oil is necessary to lubricate the tool and it is delivered through the tool on the same path as the air. But maybe you don't need quite so much oil. If you are trying to keep those nice wheels clean, you can loosely hold a rag over the exhaust. Or some devices have a means to re-direct the exhaust.
    Mar 25, 2010 | Impact Husky® 1/2" Wrench
    Need Manual for Husky Model 41214 Air Compressor
    You can get the manual for model 41214 from my dropbox area:
    http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
    BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
    http://db.tt/vQycqXIW
    Thanks,K
    Dec 20, 2009 | Air Tools & Compressors
    Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
    there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
    Oct 18, 2009 | Craftsman 1/2" Impact Wrench
    The drive just spins, does not have any torque
    needs a service at an airtool shop the o-rings get hard and start to break up ,i hope you havent used wd40 or the like ---bad news-- only use automatic transmission fluid or airtool oil, a service is not dear and you wont know yourself
    Oct 09, 2009 | Craftsman Air Tools & Compressors
    When using the tool to loosening bolts my wrench
    dont use wd40 or any of those kero basedthings in an air tool use automatic transmission fluid or buy air tool oil. the symptomyou speak of is typical of ther neoprene o/ring becoming hard and breaking up .my best advice is to take it to an airtool servic centre strange this is the second one of these in 5 minutes
    Aug 18, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
    I NEED A DRAWING THAT WILL ENABLE ME TOREASSEMBLE
    Go to chpower.com and search for your model there. Campbell Hausfeld makes the Husky line for Home Depot. Sometimes they are limited runs on certain products and you will not find any information about those tools. Its worth a shot to contact Campbell Hausfeld to see if you can get a breakdown for your tool. They do have an email and phone contact on their website. The power tools phone number is 1-800-424-8936. Good luck.
    Apr 20, 2009 | Air Tools & Compressors
    Impact 3/4" Dr. Heavy - Duty Air Wrench Logo
    497 people viewed this question
    Top Impact Air Tools & Compressors Experts
    Vernon Taylor
    terry stevens
    Are you an Impact Air Tool and Compressor Expert? Answer questions, earn points and help others
