Question about Mitsubishi WS48511 48" Rear Projection Television
Blue convergence problem
There is a blue ghosting effect that typically ghosts any text (scores, channel guide, etc) in a bow across the top of the screen. So there ends up being a blue bow from the top left to top right that sags down in the middle.
I tried resetting the convergence (I couldn't figure out how to try manually adjusting convergence) and that didn't help. From reading this board it looks like I may need to replace an IC or something, which I'm comfortable trying, but I wouldn't know where that part would be in the TV and such.
Thanks for any help - this is driving my parents crazy.
  • Mitsubishi Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneerblue convergence problem - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Blue shadow
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have the ghost look, top and bottom of the screen is narrow
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Ghosting
  • Screen looks 3D
Mar 20, 2009 | Philips 60PP9352 60" Rear Projection...
Convergance issue on one AV input only
This is not a convergence problem in the traditional sense as it would effect all inputs not just one. I would be looking at the video switching IC as the defective part. I'll look up your model to try to get you more details. Are you going to attempt the repair yourself?
Thanks,
Dan
Jan 05, 2009 | Sony KDF-50E2000 50" HDTV
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Philips rear projection tv prob
You need to replace the conversion ICs. Both of them.
Mar 09, 2008 | Televison & Video
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
