Question about HP Office Equipment & Supplies
Cartridge will not aline in a HPPSC all in one printer,scanner,copier.
I put anew d&w cartridge in and it alined and it works fine.
Thanks Clarence.
Posted on Sep 25, 2008
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
I load the document in x125 scanner, then press copy, then press Start, but all I get is several beeps from the Start button. Got new cartridges; alined and work fine from my computer.
Try to open the printer and remove the cartridges. While the cover is open, check and make sure there are no foreign objects or debris blocking the cartridge carrier's path. If all is clear, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they are properly seated in the cartridge carrier
May 30, 2011 | Lexmark X125 All-In-One InkJet Printer
I want to scan and print from my hppsc. How do I accomplish this?
My scanner icon is not visible - hp director in my computer
Jan 12, 2011 | HP PSC 1315 All-in-One Printer
Epson Stylus SX215 the ink cartridge holder won't move into position so I can change a cartridge
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Every time I turn off the printer, when I turn it back on it prints a test page. How do I stop this?
This problem is caused by not adjusting the printer after replaceing the ink cartridge. You will have to aline the cartridge by printing out a scan page then putting it in the scanner and selecting the lines that line up best for the printer. Once you have done the alinement process it will no longer do this. Every HP I have owned has done this. here is the page to go to to set it up to stop this problem. Hope this helps and thanks for using Fix-ya. Let me know if this helped.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&cc=us&lc=en&dlc=en&product=428800&tmp_track_link=ot_search
Oct 06, 2010 | HP PSC 1510 All-In-One InkJet Printer
I have a hppsc 2210 that is saying remove and check cartridge which I have done multiple times. I also cleaned the contacts. Nothing helps.
Maybe you should buy a new cartridge. This warning message usually means that one of the contacts on your cartridge has blown and when you put it in, the printer does not recognize it anymore. If that is the case, sadly, the only solution is to buy a new cartridge.
Feb 25, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hello. Having a problem with my HP printer. The light is blinking. Just changed the ink, but I am getting no results
You need to aline it push the print button on the printer then when it prints out a test page put it in the scanner and line it up, if this does not clear it try using the HP tools to do a new alignment and new cartridge install if you need help let me know.
Sep 21, 2009 | HP PSC 1315 All-In-One InkJet Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Copying anything comes out sketchy
I replaced the black ink cartridge....alls well
Mar 22, 2009 | HP PSC 2210xi All-In-One InkJet Printer
My printer is HPpsc 1610 and I am out of black ink. May I use HPtricolor#95 instead until I can buy the black? I have 3 of them on hand.
you can not replace the black ink cartridge with a color ink cartridge. the printer will not recognize the tricolor that you will put in the black cartridge area
Aug 13, 2008 | HP Office Equipment & Supplies
47 people viewed this question
Ben Johnson
