Question about Car Audio & Video
I need anti-theft code for 1990 BMW 325iC - direction on where to find cheapest - it is not available on ebay.
I need anti theft code for Clarion w/Equalizer for a 1988 Saab 900
The radio serial # is 0032578
The car Vin# is YS3AT76L8J7027597
Posted on Sep 14, 2008
Anti-theft circuit
How do you know the anti-theft is at fault here? Have you scanned the system or had it scanned? If not the dealer needs to scan it for fault codes to see what the cause of theno start is.
Sep 17, 2012 | 2003 BMW 325
My battery had to be recharged on my 1994, BMW 318... My anti-theft system and radio are not working now as a result, but worked fine before the battery was recharged... There is a CODE msg in the...
When you take the battery cables loose from an anti-theft system, You would place a nine volt (9V) battery across the positive and negative cables to hold the memory chip in the systems. This allows you to remove the battery for a period of time longer than a few minutes. The system (anti-theft) is designed with a couple of capacitors in the system that hold the charge for a few minutes to allow changing of the battery. If the battery is removed for much longer than 30 minutes then the capacitors drain and the memory is lost in the chips.
You are going to have to go to the BMW dealer and have them re-write your system, and it will cost you about a hundred bucks. They have the plug in device that will restore the system and it is not sold to the general public. That is why it is called ant-theft, so if someone steals your radio it quits working.
Nov 30, 2010 | 1994 BMW 3 Series
The anti-theft code on our 1994 BMW 740iL was plugged in after the battery was replaced + that new code has now disabled the car, as you would want with an anti-theft system. Now, no one knows the code...
For 1995 and older models.
Simply lock the door with the key from outside of the car,then unlock it. Then start the car. I think this lets the computer know that someone who has the correct key is attempting to start it.
Nov 16, 2010 | 1994 BMW 7 Series
I installed a new ecu in my bmw 316i, its now showing me code DWA which is apparently anti theft device, the car wont start how do i solve this?
it will probably have to go to a bmw dealer to be coded. your new ECU is not recognising the code in your ignition key, so it wont allow the engine to be started. you will require to produce registration docs and photo proof of ID.
Apr 20, 2010 | Anti-theft Alarm System 3 Series E90 E92...
1988 bmw 325si manufacture radio is missing but wiring cluster is intact apparently. Do i have to have a stock radio replacement or can i install a cd player deck without causing problems???
Generally you any after market radio can be installed into any car. You might have to cut the original wiring connector but basically all you need to hook up a basic radio/cd player is a positive and a ground wire. That's what powers the radio/cd player. Next all you need to do is hook up the speaker wires the unit. One other option is to check out ebay for a used radio/cd player. You will do better getting a radio that does not have an anti-theft feature. If it has an anti-theft feature you will have to enter a code to make it work.
Feb 11, 2010 | 1988 BMW 3 Series
I have a 1992 bmw 325i.The stereo is not working.
you need the anti-theft code for the radio....the radio should safe theft lock or something similiar to deter theft.....unfortunately you will need to pull the radio to get the serial number off the radio and than beg and plead with the dealer to give you the code without paying for it......you may want to check the owners manual for the radio code......some past owners sometimes will write the code in the book......
Sep 14, 2009 | 1992 BMW 3 Series
Need the anti theft code for 93 BMW 325 it has the tape deck in dash
The anti-theft code is different for each vehicle. You will need to contact a BMW dealer in your area and provide proof of ownership to get the code. There is no single code for all BMW's. If this were the case, it wouldn't be very secure.
Aug 22, 2009 | BMW Car Audio & Video
Need radio and anti-theft codes for my 96 bmw
You Willl Need To Contact BMW And Give Them Your Vin Number So They Can Give You The Code
Jun 13, 2009 | Vehicle Parts & Accessories
Need to know how to program the code in to my 1993 bmw 740 I
The BMW anti-theft radio circuitry is designed to essentially render your radio unsalable if it is stolen. If the radio is subsequently electrically reconnected, it will not operate until a five-digit security code assigned to your radio is entered. The anti-theft features and operation are as follows:
  1. After the ignition key is removed, the red "anti-theft" LED will continuously flash, drawing attention to this feature.
  2. Should anyone, such as a thief, touch any push-button on the radio after the key is removed, the anti-theft inscription will flash and a warning tone will sound for 5 minutes or until the ignition is turned ON .
  3. Should the voltage supply to the radio drop below 5 volts due to a dead battery, electrical repairs, or radio removal (such as theft), the radio will not function when voltage is restored. The word "code" will show in the display only.
  4. The proper 5-digit code shown on the TWO CARDS SUPPLIED TO YOU must then be entered (using the proper number radio push-button selectors in the bottom row) when the radio is on and the display shows "code". If the correct code is not entered in three successive tries , the radio will not accept entry until the radio has been left on for one hour with the ignition ON . IMPORTANT: When entering 5-digit code number, be sure to complete sequence number of that 5-digit code. For example: Code No. sequence is 43215 and you mistakenly enter 42 instead of 3, continue the code number sequence of 215 to complete that entry. The radio will not operate and "code" will reappear in the display. Re-enter the correct number sequence of 43215 and operation of the radio will continue. The likelihood of guessing the correct code is extremely remote. The radio is, therefore, unsalable to a thief. NOTE: If an audible beep is heard while entering the 5-digit code, STOP immediately ! Begin entering the code again, starting with the first number of the 5-digit code.
  5. The code card should be placed in your wallet, or with the vehicle title papers for security as deemed necessary by your individual needs.
  6. Should radio or electrical repairs become necessary, please give the repairing facility the radio code number. If you do not, only authorized BMW dealer personnel can obtain the code from BMW.
  7. Should you lose your code cards, contact the nearest BMW dealer who will then obtain your code from BMW. You may be charged for removal of the radio to ascertain the radio chassis number.
  8. WARNING: FOR YOUR PROTECTION, CODES WILL NOT BE GIVEN OUT TO ANYONE UNDER ANY CIRCUMSTANCES OTHER THAN AUTHORIZED BMW DEALER PERSONNEL AFTER PROOF OF VEHICLE OWNERSHIP AND PROPER IDENTIFICATION IS ESTABLISHED.
  9. Install the 2 enclosed warning decals in accordance with motor vehicle regulations.
Jun 04, 2009 | 1994 BMW 7 Series
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
