IT IS A 2002 CURTIS MATHES TV MODEL NO. CM32020S WHEN YOU PLUG IT IN TO POWER ALL THAT HAPPEN IS THE RELAY IN THE BACK OF TV CLICKS AND THE LITTLE LIGHT ON FRONT OF TV FLASH ON AND OFF.
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
SOURCE: Curtis Mathes TV- Model #CM19001-
i only get channels 2-13....where is the switch on the back to switch it from antenna to digital??
Posted on Oct 11, 2008
  • 49 Answers
SOURCE: I have a Curtis Mathes
Check and see if you can restore the defaults in the main menu. Try to unplug it for 20 minutes.
Try using different connections... example dvd or game or what ever and see if anything changes.
If you try all of this then your going to have to consider some major repair of the turner or main board and cross your fingures its not your main panel/ Screen since this will exceed the cost of a new unit. Go to the manufacture and see if they wil extend you auth for a repair for parts and perhaps labor.
Thanks,
Shawn
Posted on Jan 31, 2011
gopakumarg43
  • 72670 Answers
SOURCE: need owners manual for curtis mathes tv model #cm32020s
Click here to downlaod the user manual to your tV.
Posted on Apr 29, 2012
How do I change a Curtis Mathes Analogue to Digital
You can't. The only way to change it would be to go and buy a new TV. Unless you're asking about hook a game console to it, that's a different procedure. The analog refers to the internal workings of the TV its self.
Nov 07, 2014 | Televison & Video
Curtis mathes tv cannot change aux back to normal channel like three. how do you get to get dvd from aux to normal channel.
Just contact the folks at the link below:
http://www.curtis-mathes.com
They are great a helping folks with problems with their Curtis Mathes televisions and stereos; and they do it for free :)
Feb 22, 2014 | Televison & Video
Half of my curtis mathes 46" LCD tv screen has
open it power up the tv and press down the strip/ribbon down ans see which one is loose
May 26, 2013 | Televison & Video
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis Mathes 27" TV
better to replace a/v jacks as you have already soldered it
the problem is due to jack only.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
