Question about Crown MA-5002VZ 2-Channel Amplifier
Crown Macro tech 3600 VZ Amplifier
It has gone faulty after being dropped. Both channels are getting much hotter than normal. I need to thoroughly check it out. I am a highly qualified engineer but need a circuit diagram/setting up info for this 'beast' of an amplifier.
I'm based in the U.K. thank you very much indeed for any help offered.
Dektorr
  • 3 Answers
Maybe its loose connection or the wiring
Posted on Sep 26, 2008
  • 2,071 Answers
How to know this Amplifier v13 MRV-F705 4 channel and max 3600 watts .... how to get the details or image?
That model number sounds like an Alpine model number. What exactly are you seeking? An owner's manual or service manual? Please confirm the brand as well.
Oct 14, 2016 | Car Audio & Video
Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Sep 14, 2008 | Crown MA-5002VZ 2-Channel Amplifier
My amplifier is to hot then off
use compressed air to blow dust out of unit, If it gets hot under no load condition you have a bad diode and resistor on one channel. A complex repair on this amp for an experienced tech. Probably more economical to replace it( for your next pro amp i'd recommend crown or qsc).
Mar 22, 2014 | Technical Pro Ax3000 3000 Watt 2 Channel...
Unit turns on but goes to red
Make sure that no more that 8 ohms are hooked up for each speaker. Or whatever the rating is for that amp
Oct 19, 2013 | Crown MA-5002VZ Macro-Tech Professional...
I have acquired a CE2000 that has a dead channel. What is the most common items that go bad affecting one channel only? Also, Are schematics available?
If you turn up the faulty channel and you can hear nothing, then it could be the pre-amp that's gone, otherwise it could be the power amp. The most common cause is a faulty output transistor. It will be open circuit, not short as that would blow the fuse. Though some amps do have a fuse for each channel. The good news is that the other channel is the same as the bad one. So all readings taken with a multimeter should be the same. So if you find a bad/wrong reading IE one that doesn't match the good channel, you have found the source of the trouble.
Jan 26, 2011 | Crown CE2000 2-Channel Amplifier
There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Mar 04, 2010 | Crown XLS 602 2-Channel Amplifier
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the...
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Dan
Jun 30, 2009 | Crown XTi 2000 2-Channel Amplifier
I need the schematic for the crown amplifier xti 1000 crown xti 1000 2-channel amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Jun 28, 2009 | Crown XTi 2000 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
6000d amplifier cutting off
Hi...
Crown has posted on their website all the tech info you can probably use for your situation.
Cheers!
Jan 15, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown MA-5002VZ 2-Channel Amplifier Logo
1,153 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
