Question about Sony Ericsson W550i Cellular Phone
I turn my phone on and the middle of the screen is the regular background but the top and the bottom are blue bars going across and when you press a button the usual buttons that say "ok" or "play" or "back" are on top of the screen
    Brigadier General:
  • 7,752 Answers
Reaplced the lcd
Posted on Sep 21, 2008
How do I find tools and options
Sorry i dont know what computer you have. But if it is a windows, go into start and there should be control panel there (thats tools/options.
If you have a apple computer on the bottom there are floating icons click the one that looks like a gear.
Dec 22, 2015 | Computers & Internet
A colour bar blue on the bottom and green on top of42" LCD
it sounds like a lamp problem, did the support guys say anything about lamp possibly failing?
Apr 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
I want to download its software how can i do it?
By software do you mean the phones software/firmware?
If so...
you will need to download EFS, find that here and an alternative version here (use this one if your pc flags the first one as a virus)
  • First, on your pc's desktop, create a new folder by right clicking in an empty space and choose new - folder, name this LGAPP or something that you will remember.
  • Now open the EFS program, but don't connect your phone yet. You will see a large empty screen with an "explore" button on the top bar, press this.
  • A smaller empty box will open in the middle, click cancel on this one.
  • You will notice that the screen is now split into 4 sections. In the bottom half is your Pc's files, the top half will show your phones files once we are connected.
  • In the bottom left section, find your desktop where you saved the new file that you named before. Open the desktop folder and then open the newly named file, the bottom right section should be empty.
  • Now, put your phone into "Data mode" by going to Settings-Phone settings-Connectivity-USB connection mode-Data mode. Return to the home screen.
  • Now on EFS close the first window so you are back to the empty screen with the explore button at the top. Click "explore" again, the small empty box will reappear.
  • Now when you connect your phone you will have about 3 seconds to tick the box that appears in the top left of the small box and then hit connect in the bottom right of the small box. If a warning appears and says something about a port, just disconnect and reconnect your phone.
  • Once connected you will see your phones files in the top half of the screen.
  • Make sure that the bottom half is still showing the folder you named earlier.
  • In the top half, right click LGAPP and click re-name, LGAPP(text) should turn blue. Now type TOTO and click in an empty space until it is no longer blue
  • Right click TOTO and choose refresh. This enables you to copy the protected files in your phone
  • DO NOT RENAME TO SOMETHING BLANK!!
  • Your phone will disconnect itself
  • You will get a yellow screen don't panic, just reconnect
  • You will notice that a "ghost" LGAPP folder has appeared, ignore it
  • Now right click on TOTO and choose "read", after a few seconds your files will start to copy to your pc, this will take about 40 minutes, so sit back, go watch tv or somethin just don't turn off your pc or your phone, in fact, don't touch either.
  • Once this has finished you will have a copy of your own firmware backed up. Save this at all costs, put it on a memory stick or something.
  • In the top left section scroll all the way to the top and click the folder with no name (very top one) you should now see TOTO again in the top right section.
  • Right click on TOTO and rename back to LGAPP, then right click and refresh again.
  • Now click on "Disconnect" on the middle bar and choose "yes" from the pop-up. Your phone will now reboot. Thats it your done.
Or go to the LG website if it's Sync software you are after.
Jul 06, 2010 | LG KU990 Viewty
Blue line across bottom of screen on a Sony LCD rear projection
Contacted Sony Eletronics and was told it could not be fixed . Sony
offered a great deal to trade in for a much better one : a 55" Sony Bravia valued at $ 2,000 for $ 825 . Not bad !
Feb 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
How to use face detection
Hi
Turn on camera as if you were taking a photo. Whilst holding phone vertically, in bottom right of screen you have a box image with lines. Below this on the keypad you have a 'soft key' (right hand '-' key) Press this and it takes you into camera settings. Turn phone horizontal and there is a menu across the top of the screen. Move cursor to the right using directional keypad until the little man with a box around his head is highlighted. Now pressing up and down on directional keypad, you should be able to highlight on / off with a white band? With desired option highted press 'ok' in middle of directional pad. That should now work.
Apr 29, 2009 | Samsung U900 Soul Cellular Phone
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Ericsson W550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
