Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer 80Series water leak
My washer started leaking last night. It finished the load of wash no problem but the drip pan was covered with water. Probably 2c from what I soaked up with a sponge. Thank god we have a drip pan. Water still managed to get on the floor though it didn't seem that the drip pan overfload. Weird.
The maschine is a little over 5yrs old and we had the pump replaced about 5months ago. I took the hose on the back of the machine off thinking it might be clogged. When I took it off there was still clean water coming out of the maschine. I then tipped the washer over to check the pump. I noticed a little piece of cardboard at the bottom of the pump but it didn't have any sign of being wet...I can not tell were the water is coming.
I really don't want to spend another $200 for service on this machine. Does anyone know where the leak is coming from?
    Sniper:
  • 88 Answers
First of all, you never want to tip this machine over, it can cause oil to leak from the transmission. The best way to locate the leak is to fill and run the machine with the cabinet removed. Begin by removing the two trim caps on either end of the control panel, they clip on, and should pop off by hand or a slight pry with a flat screwdriver. Then, remove the two screws securing the panel to the cabinet and flip the panel up. There should be two clips securing the cabinet to the frame (gold colored). Pop out these clips with a screwdriver for leverage. Next disconnect the wire harness from the lid switch connector on the cabinet. The cabinet should now be ready to pull off the frame. Plug the machine back in and set it to run a normal cycle, let it fill and agitate, (some models will not agitate without the lid switch being closed, in which case you will need to use a jumper wire). Biggest problem areas are the Pump, water valve, hoses, or possibly the plastic tub itself.
Posted on Sep 14, 2008
1 gallon of water leaks out the bottom (overflow?) dripper with every load.
your pump seals are bad,this is a cover to keep the pump dry if something up above leaked,but from the pics it looks to be the pump especially with all the water leaking,just replace the pump unit
May 04, 2012 | Kenmore 98702 Stacked Washer/Dryer
My kenmore washer has just started this week leaking water underneath somewhere!! I noticed water down the side next to the wall & behind the washer. I then placed a few small towels behind & down...
This is either your water pump, inlet valve, or you have a hole at the top of the outer drum. Try using the small load water level, if no leaks try medium. Also try seeing if the hoses are leaking. I also have seen mice bite holes in the drain lines. I hope i have helped you. God bless!
Aug 20, 2010 | Kenmore 26442 Top Load Washer
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 27841 Top Load Washer has developed a water leak
Hi, Check the pump. Tip the washer back after the load finishes and see if the pump is dripping. The pump is located on the front side of the motor. If the leek seem to be in the front center of the washer, it is probably the pump. I hope this helps. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Kenmore Washer Leak
Check the back of the tub as the water is coming in. Sometimes the water inlet gets knocked out of line if the machine shakes a lot or gets moved.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Cold water leaking in washer tub
Replace your fill valve and you will be back in business.
May 27, 2008 | Washing Machines
Kenmore Elite HE3
I don't know if this will help or not, but my machine has gone through (2) fill valve assemblies so far. In one case, it wouldn't fully shut-off and was also erratic. I replaced it (very easy to do) and that fixed the problem. I think my machine is an HE2, but I'd guess it's probably the same parts... (Parts available through the Sears web site. The last one I bought was around $55 for the assembly.)
Jan 02, 2008 | Kenmore 42822 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
149 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
