Question about Dayton Electric Heater
Eb series electric heat/air cond./repair
The unit turns on but will not blow hot or cold air
  • Anonymous Mar 22, 2014
    my electric fireplace is blowing out cold air when turned off. otherwise it works fine when turned on
  • 108 Answers
I need more information to help you. When you say it "turns on" what does that mean? Only the fan works? If so does the compresser run? If not, the start relay could be the problem.
Ray
Posted on Oct 25, 2008
1999 crown vic air cond blows out hot air instead of cold, details on how to fix, valve works but door won't open and shut"
Go to ur local library and look for motor manual and copy part u need look under heating and cooling
Aug 05, 2014 | Heating & Cooling
Ac blows out hot air in hot climate and cold air blows out the heat when i turn it on
bmw 5 series on 2005 2.5 diesel when i put the heats on hot air it blows cold air.
Nov 25, 2013 | Lincoln Mark VIII Cars & Trucks
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
97 f150 air cond. blows hot heat blows cold
if all this happened while doing spark plugs look on the pass rear of the engine for a vacuum line that came off or broke while moving this around during spark plug replacement
Jul 02, 2012 | Cars & Trucks
Our air con runs, on heat, and after a time cuts out, blows cold and makes a sort of hissing noise (but not a real hiss) and then shuts down. It then restarts after a couple of minutes. Is this normal?
Yes.Think of a heat pump as a A/C in reverce in cool indoor coil is cold&outdoor coil is hot.Naw indoor coil is hot &outdoor coil is cold&fan is pulling in cold air from outside.its going to iceup& go into defrost cycle.If your unit has a timed defrost every 30,60,or90min.(witch ever yours is set for)Defrost control board checks a sensor on cond.coil,if it is frozen unit goes into defost.You will here a swishing noise,iis the reversing of refrigerant.you will also notice the outdoor fan is not operating&at termanation of defrost fan will blow out steem.the other metod is on demand defrost.when coil freezes unit defrosts.
Mar 02, 2010 | Heating & Cooling
Ford Explorer, 1998, V6 4L the cold and hot air is only blowing HOT air from interier air unit, when swiched to cold and the air cond is not working ? thankyou dgp
Check all the vacuum hoses connected to the vacuum motors to see if they are disconnected or damaged. A fairly common one is the vacuum hose leading from the engine to the heater controls on the dash. It gets roasted from engine heat. G/L
Sep 28, 2009 | 1998 Ford Explorer
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
My carrier air con is only blowing cold air and i need the hot
It sound like the heating sequecer maybe have gone bad on the fan coil unit that you have. You need to call the maintenance personnel that does the work where you live or a service company out to repair the unit because since y0u only rent it is their responsibility to provide youp with heat and if by chance that you have a heat pumo unit then you definately want them to get on the roof to fix the problem. Remember to always change oyur filter inside when ever you get your electric bill because even though it's theeir unit it's your electric!
Jan 05, 2009 | Carrier 38CKC042 Air Conditioner
Dayton Electric Heater Logo
65 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
