Question about Car Audio & Video
Xtant 3300X schematics
I need them badly in order to repair my amp.
Powers up but no sound
Posted on Sep 15, 2008
  • 631 Answers
Xtant never released the schematics for their amps.
What sort of problem are you having with yours?
  • josh knapp Aug 31, 2010
    ummm it powers up but no sound it says offset and i dont know what to do have any answers call me 7348192590 my name is josh
XTANT AMPLIFIER GETS UNUSUALLY HOT WITH MINIMAL LOAD.
Check your ground wire. If its loose or bad. It will cause your amp to run hot, and can damage it
Nov 10, 2011 | Car Audio & Video
I need a schematic shhet for the 4010 dinosaur amp have bad tda2040a need to replace
Companies are stingy with schematics. If you know the part is bad just replace it. Hint: MOST of the companies use the manufacturer's application note schematics for their designs. Here is one for the TDA2040:
http://circuitdiagram.net/20w-hi-fi-power-amplifier-with-tda2040.html
When ordering the part make sure to get either the H or V version to match the one you are replacing... the leads are pre-bent. Use thermal compound grease and if there is an insulator make sure it is OK. Often there is a shoulder washer insulator for the screw.
May 06, 2011 | Orange Amps Orange TH30H Guitar Amp Head
I need the schematics for a Marshall MG-10KK guitar amplifier in order to repair it! I'm a good technician but I don't speak english very well... rsrs Thanks!
Most of the problems with the small guitar amps are blown power amp chips. They usually use chips like the TDA2030 which look like a power transistor.
Most other problems involve broken connectors, bad solder joints or cracked circuit boards. The power supply area is so simple one doesn't need a schematic for that part which is usually just three terminal regulators for +/-15 volts. Schematics are often hard to find.
Try this site, although this is a different model, much of the schematic will likely be the same.
http://elektrotanya.com/marshall_valvestate10_10w_8001_8010.pdf/download.html
Nov 17, 2010 | Marshall 15 Watt Guitar Amp
Are xtant 604x sub amp
yes that is a badass amp do u wanna sell it
Feb 26, 2010 | Xtant X604 Car Audio Amplifier
The overcurrent protection light keeps coming on; i am using the proper guage wiring and the correct fuse size i have adjusted the subwoofer control down on the deck and also the amp itself, the deck is...
How long has it been since you cleaned it with dust off? Xtant say's once a month. Dust can create a big buildup of static on the boards and anything is possible. Hope this helps
Jul 18, 2009 | Xtant A3001 Car Audio Amplifier
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Xtant 3300x
It sounds like it's going into protection mode.
Do any of the channels pop when it's switching on and off?
If you power it up via a single 15 amp fuse (in series with the B+ line), does it blow the fuse when it powers up?
Sep 16, 2008 | Car Audio & Video
Xtant power amplifier
Did you try hooking the amp up to see if it works?
Use a relatively small fuse (no larger than 15 amps) in case there is a serious problem. The small fuse will help protect the amplifier.
The following page will help you with basic repair. Read through it to familiarize yourself with basic amplifier components.
Basic Car Amplifier Repair Primer
Let me know if you have any other questions.
Aug 23, 2008 | Car Audio & Video
Car Audio & Video Logo
335 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
