Question about Sony Cyber-Shot DSC-F717 Digital Camera
Yellowish/Green cast seen through viewfinder
When I look in the viewfinder, it has a yellowish/green cast. Colors almost look b&W. Flash is not popping up.
Thanks,
Claudia
  • 1 more comment
  • Claudia Sep 14, 2008
    Camera was sent back and repaired several years ago. I did the test for that CCD issue and it does not look like the test results. When I look in the viewfinder it is almost black and white with a greenish/yellow tint to the screen. On the menues the selections appear yellowish.
    Do I need a new battery?
    Thanks for your help.
    Claudia
  • Claudia Sep 15, 2008
    I though maybe the white balance was malfunction too but that was not it.
    I found that you can reset the camera and it will reboot with mfg. settings. Still did not work so I took the battery out waited 5 min. or so and wa la, problem fixed. Just taking out the battery might help for some but the rebooting and then taking the battery out worked for me.
    Yippee!
  • Claudia Oct 21, 2008
    Well, the green tint is back again! :( I found somewhere in this forum that 2 others had the same problem. He said to tap the bottom of the camera. Didn't work for me. Today, I pulled the camera out and tried again. I reread the 2nd persons comment and it said he tapped the "right" hand bottom of the camera. I did that and it works. I am so happy. I just don't want to buy a new camera right now. The one I want is pretty $$$. Thanks again for this forum. Claudia
  • 10,594 Answers
Symptoms of your DSC-F717 shows problem in its CCD Imager IC and needs to replace.
Sony announced scheme of free of cost repair for your camera model with same symptoms. Click Sony CCD Issue for details.
Regards,
Posted on Sep 14, 2008
  • Shahid Electronics
    Shahid Electronics Sep 14, 2008
    If you think its not CCD issue, then check its white balance for color tint problem. Its described in user manual and make sure camera get good white balance adjustment.
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
Yellowish green picture hitachi cp x328
one of your primary colors are missing could be due to the cable (ck pin if bent) or ck the pin on the projector.
Jun 01, 2010 | Hitachi CP-X328 Multimedia Projector
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
The screen turns yellowish
That is true, problem is as old as lcd projection. Suggest buying a dlp product. they don't color decay
Nov 26, 2008 | Mitsubishi HC5000 LCD Projector
Yellowish-Green LEAK HELP!
I am guessing that you may have mold (green) in the water coming from your Air Conditioner or from the water channels where the water flows from the car vents to the ground. Usually green is the coolant. Could also be a prankster the poured some lime flavored pop/soda under your car or one leaked in the trunk? Did someone else park there and you are seeing their leaked stuff? Without more info, this is just wild guesses. Where is the leak seen - inside the car? under the engine? floor of a garage? outside in the street? Maybe even windshield washer fluid was that color if it spoiled?
Oct 24, 2008 | 1998 Pontiac Grand Am
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
LCD display has a yellowish tint
This is a defective CCD problem known to Sony. They will replace it free of charge and even pay for the shipping. For more details go here for the link: http://www.imaging-resource.com/badccds.html
Dec 04, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
175 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
