Broke a cpu pin on my xfx 780i sli motherboard
  • thermaltake1 Sep 14, 2008
    its a socket 775 the pins are on the motherboard not the cpu
  • 160 Answers
Broken cpu pins cannot be repaired,you have to replace the cpu.
Posted on Sep 14, 2008
No post no beep
check your hard drive and make sure it's connected properly and set for master, not slave.
Feb 14, 2010 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
A few bent pins on socket 775 mb, NForce 780i SLI. How can I fix this?
which pins are bent? You may be able to GENTLY bend them back iinto position. I have used the end of a ball point pen, the click kind with a hole at the end to slip over the bent pin and bend it back.
Don't forget to rate the advise!
Jul 31, 2009 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Is it compatible
Hi playboyalive, to answer your question! (Yes) the,
XFX nForce 790i Ultra SLI Motherboard will support Intel's core i7 extreme edition multi-core 3.2GHz CPU. The board can go higher. The highest tested by XFX is Intel's 3.73 GHz multi-core CPU. You can see all supported CPU's at the XFX link below;
The above link was opened from this XFX link;
Thank you for using FixYa playboyalive!
Feb 04, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Mar 27, 2007 | ASUS P5N32-SLI Deluxe (890552603794)...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
