Question about Philips J44414
Help no picture and when i attached to usb port it showed installing new device but didnt.
My asus was died. the indicator didnt show the signal, how i repair that?
Hi
Almost always the problem is the USB port that you use for this device. Even careful use means pressure is put on on USB dongles, adapters and flash drives, either bending the deivice and affecting the contact of the compnernts inside and/or the same for the components and elements inside the USB port on the computer itself.
Gravity, accidental knocks and the unwitting placement of objects ontop of the USB device can bend the devive and the port, causing damage.
The best ans safest way to use USB devices, is with a short USB Male to Female extension cable. Connect the cable to the computer and alwaysv attach the USB device to the female end of the cable instead of directly to the computer and place the USB device flat on the desk or table. This means there is no downward pressure on the device or the USB port.
Hold the device up to your eyes to see if it is bent. Shake it to hear if there are any loose connections. If so, you can open it and if you have a soldering iron and some solder and some superglue, you can try to fix the damaged connection and then glue the device bacl together carefully.
If the USB port on the computer is damaged, try a different USB port.
If no solution arises from the above, buy another wireless adaptor and a USB extension cable. Both of them will only cost a few dollars.
Hope this helps.
Aug 24, 2011 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Onboard USB prrs malfuntion
Try re-installing the motherboard drivers. Here's a link:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2V-MX-SE-Bios-0502.shtml
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | ASUS M2N-MX Motherboard
TH1602-A
I had decided to reload the firmware. Initially this did not work as the device could not be found. I then found a mention that if you reset the device and then as you plug it into the USB port hold the Play button in... you should see it find new hardware (ROM initialzing). After this I had to reboot. It still wouldn't start but now I was able to load the firmware and it came up fine after this. This method does format the drive so everything is lost (not even the initial software was on it).
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2557
Nov 16, 2008 | RCA TH1602 MP3 Player
Toshiba Satelite a135 s2386 USB problems...
this is the fault of your usb port, its a hardware problem, its better not to use that port, use a usb hub if you want more usb ports
Nov 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Can't get the software for my new Panasonic TZ5 Lumix to load into my iMac! iMac doesn't recognize it as a CD. Urgently need to download my photos to update my website! Help! Patti
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "falsh disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you with your problem! good luck!
Nov 01, 2008 | Cameras
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Aspire 3610 USB ports
Device manager shows the USB port if they are attached to you notebook. And in your case they are attached. So it will show it. Now in your case the problem is in your USB. Get it changed. If it is in warranty peroid then dont u take any risk. Let it be replaced. Or give your notebook in warranty period to the company from which you bought.
Sep 26, 2007 | Acer Aspire 3610 Notebook
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Philips J44414 Logo
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
