that is 2 12 hitting 150 db you got to know what you are doing
also me says guest
solution 3
i am running a sx1250.1 digital and 2 12" L7's with a 0 gauge wiring kit that also brings a big part in what you are getting out of an amp.
Ill tel you right now you got a 1 or 4 ohm load going to your amp. The amp is made for a 2 ohm load at approx. 1100 watts so in that fact you are only giving that sub around 700 watts at 4 ohms and a 1 ohm load will blow your amp in a quick hurry.
You would need the L7 dual 4 ohm subs they cost $200 each and the zx1000 amp runs $400 each.
However, the zx1000.1 amps will barely push them (L5 1200 watt would be a better choice on that amp) so the total cost shipped with authorized kicker warranty for 1 year would be $1200.00
I do however have 1 new in box single 06S12L7 dual 4 ohm in stock for $150 shipped its under full manufacturer warranty as well. the amps you need to push the rated power for L7 subs is the zx1500.1 and they are $600 each all of these prices are nearly 1/2 of retail that kicker requires its dealers to sell at, however i am a distributor so I can sell at w/e price I want :)
I can get you into a much better sub and amp combo for less but it isn't kicker brand. I went from 4 L7 12's running zx1500.1 to each sub for a total of 6000 watts RMS and hit 151 db and switched to Hifonics subs and amps and hit 157.3 with only 2 12 inch square brutus subs and 1 2000 watt RMS class d brutus amp. Hifonics will even warranty a blown or burned sub but kicker will not because they know they have voice coil heat issues with them. I have been using the same 2 subs and single amp for 9 months now in serious street beat comps and have never had an issue other than breaking car glass, however with the kicker sub amp combo in 7 months i went through 5 subs and 2 amps and never broke a window.
I can get you the brutus amp for $350 shipped and the subs for $260 a pair shipped or $600 for the combo shipped which is 1/2 the cost of the kicker at twice the quality and sound output. Hifonics is the only company to ever win more than 150 sanctioned events in a single season and they hold the record with over 210 wins in a season
let me know what you think on the price and I will do what I can to help out.
you would need the L7 dual 2 ohm subs they cost $200 each and the zx1000 amp runs $400 each.
I do however have 1 new in box single L7 dual 4 ohm in stock for $150 shipped its under full manufacturer warranty as well.
