Question about Panasonic Palmcorder PV-D209 Camcorder
Tape Release Button not working, Can't get tape out!!
I have a Panasonic Palmcorder, Model PV-D209. The tape release button does not respond so I cant get the tape out. Record, VCR and all other functions are working, I just cant get the tape out!! I tried both battery power and electric power, but nothing helps.
How do I fix it ? Thanks!
  • MrsChrisC Sep 15, 2008
    Guess what, I fixed my problem by accident. I tried to slide the eject button over and lifting it upwards with my fingernail. It popped off, and while doing so, the tape ejected. Under the button is a white plastic lever. I can use a small screwdriver to move the lever in order to open the door.
    I put the blue button back on again. I see that the problem is the blue lever is not meeting up with the white lever to push it over.
    I'm glad I can get my tapes out, however, now I don't want to leave it exposed to dust with a hole open.
    How can I fix the button so it meets up with the lever properly?
4 Suggested Answers
  • 19 Answers
SOURCE: "Tape Not Inserted" on Panasonic PV-DV203 palmcorder
hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
Posted on Nov 10, 2006
SOURCE: Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
Posted on Jun 13, 2008
arthurroger
  • 170 Answers
SOURCE: PANASONIC PALMCORDER IQ (PV-IQ204
Try removing the battery. While holding the eject button, re-insert the battery.
Posted on Dec 06, 2008
Testimonial: "PERFECT..THANK YOU BRILLIANT PERSON(ARTHUR ALDRICH!"
I cant open the door to eject or put in a tape..
Shut it off, remove battery, install battery , turn it on and try it again, usually it works.
Mar 31, 2016 | Panasonic Palmcorder PV-D209 - camcorder -...
Vhsc wont record unto my vcr
i have apanasomic ty-la1500 lamp its asking me to replace lamp but i repalced it 3 months ago ,can i reset it
Jan 23, 2009 | Panasonic Palmcorder PV-D209 Camcorder
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic S-VHS-C movie camera
1. Take out the tape - AND TURN THE CAMERA ON.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS
CREDIT TO LABBER
Feb 16, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic palmcorder
this is either a sinc problem or you tryed copying a write protected disc.
Jan 02, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Power save function
Do you put a tape in when you try to record or do you connect to a DVD / VCR so that it records onto the DVD or VHS?
If this is how you do it, then I will recommend you use a mini DV tape instead.
Hope this helps.
Osei71
Sep 10, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic dv53
. Take out the tape - AND TURN THE CAMERA POWER ON
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
Apr 22, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Nov 08, 2006 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic Palmcorder PV-D209 Camcorder Logo
120 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
