This projection TV was moved and now the it seems the blue projection is out of alignment. When viewing the picture especially text on the screen, an exact blue image is seen diagnolly from top left to bottom right. I have worked on tvs in the past but never a projection before I would like to know if this is an easy fix and if there is anything I should be cautious of when attempting to do so. Any help would be appreciated. Thanks.
if problem occured while moved tv,may be solder or mechanical adjustment-is blue image square and proper shaped (meaning if you could move blue image,would it perfectly overlap other image?) if so,maybe yoke on blue crt has moved or centering magnets on blue yoke have moved-if blue raster is distorted,possible solder on convergence area is bad-blue convergence ic may have bad solder on its pins
Was this solution helpful? Show your Appreciation by rating it:
