Question about Acer Aspire 5600 Series 5630-6951 Laptop
My speakers My sound is not working all it says is no audio device output working. I was fooling around trying to hook up some speakers and I think I accidentally deleted something.....I have a Acer laptop with Vista.....Please help
  • 95 Answers
You need to go to the acer site and download the correct driver
Posted on Sep 14, 2008
No sound from computer speakers
tried to hooked in other audio port of the pc let see if you can get sound there. if not, to isolate if the cause is with in the pc or at the powered pc speaker you can hooked your computer speaker in other device like tv. then if you can get sound output from the tv that was mean your pc has problem with the audio out. but if you can not get sound from the tv your pc speaker need for repair.
Nov 12, 2012 | Audio Players & Recorders
I have them hooked up to the computer but they stopped the noise did i hook them up in the wrong hole in the back of the computer? or did they stop working i think they are still working but i think i...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
May 06, 2011 | Sony SRS Z50 PC multimedia speakers
Well we had it hooked up a long time.disconnected it about a yr ago.Tried to get it to work to day and it would not.Do you think i need instructions on how to hook it up or download something for it to...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Harman Kardon HK206 Computer Speakers
No speaker sound
There sometimes are three connectors on a sound card that are similar. A speaker output, microphone input, and stereo headphone output.
Try all three, if you accidentally put it on the microphone input you won't get sound output of that one, so try another.
Also, check in the speaker control panel for the sound to be checked to mute or volume turned all the way down.
Aug 01, 2010 | Dell Dimension 8200 PC Desktop
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Sound
You will want to check a few settings in the control panel of your computer.
1. Click "Start" --> "Control Panel". If your using Windows XP, I recommend you click "Switch to Classic view". Double-click on "Sounds and Audio Devices". First, make sure the volume is not muted. Then click on the "Audio" tab. Make sure there are devices listed, and that they are not grayed out. You may try clicking "Use only default devices". Click apply and test the sound again. If this does not work, uncheck the box and click apply again.
2. The problem may be with your audio drivers. Do a google search for "realtek generic audio driver", or click this link Realtek '97 audio driver.
Download the driver and install it. This will install generic drivers for sound cards, which work with many different brands. Try the sound again and see if this works.
Jul 07, 2008 | E-Machines eMachines Desktop PC
How can i install a new Computer Speakers? I had some speakers on my computer and it stopped working. I thought my speakers were messed up so I got some new ones and now my computer says that there is no...
This sounds more like a sound card issue. Go to Control Panel, System, Device Manager and check your sound card.
The speakers get plugged into the audio output jack on the back of your computer.
Jun 03, 2008 | Audio Players & Recorders
Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Oct 07, 2007 | Televison & Video
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No speakers?
if you are trying to get rid of all the speakers & just hooking up the sound to the tv speakers, what you need to look for on the back of the dvd system is you need to find an audio out. I know the is one or two audio input, but I do not think there are any audio outputs. I don'e think you can get sound out of this system without your speakers hooked up. sorry.
Oct 31, 2006 | Sony DAV-SA30 System
Acer Aspire 5600 Series 5630-6951 Laptop Logo
66 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
