Question about HP Presario V2401cl Notebook
Power issues with laptop
Hi I have a HP Pavillion ze5345us laptop that was workiing fine until the other day. Now when I plug in it shows it's charging so I fire up the computer and it gets to the main screen with icons and all then it shuts down. I have to remove the battery and put battery back to get it to restart but it keeps doing the same thing. When I remove the battery it has no power at all to the laptop. The power jack is firm so I don't think it's that. The battery is **** but it has been for a while and holds no charge. I have taken apart this laptop and cleaned and made sure things were tight. I am at my wits end. Any idea's?
  • wildrescue Sep 15, 2008
    I have already replaced all fans including the heat sink. The issue is a charging or lack of charging problem. The computer isn't on for even 3 minutes before the computer shuts down.
    The charging light is on until it shuts off then it goes off and the computer is electrically dead until I remove and replace the battery and the orange light that shows the battery is charging comes on. I cannot run the laptop by the wall charger alone there is no power to start the computer. It is only when the battery (which is old and doesn't hold a charge anymore) is in the computer that I can get it to start up for even the 2-3 minutes. I wish it was as easy as an overheating problem.
    We have tested the wall charging unit and find nothing wrong. We have checked the power jack and it is solid. Should I just get a new wall charger? Could it be just that?
I HAVE A NEW LAPTOP (EVEREXGREEN) AND DONT KNOW HOW TO USE THE ARROW. I TRY WORKING ON THE AREA THEY SAY WITH MOVE THE ARROW BUT IT ISNT MOVING. DO YOU HAVE A QUICK ANSWER FOR ME. THEANK YOU
Posted on Oct 10, 2008
  • 186 Answers
As per your description, I understand that the issue is because of Overheating of the Notebook or the Cooling Fans are not functioning properly.
First of all, keep your arm at the bottom of the Notebook and check if you can feel any heat than normal and make sure that the cooling fans of the Notebook are spinning and are clean from dust. Also see that the Cooling Fan Vents are free from dust. Clean the above mentionad parts using a Air Blower or Vaccum Cleaner if possible.
There will be settings in BIOS by default where the computer will be turned off if the temperature of the CPU reached or exceeded a certain level to prevent further damage to the computer or processor and motherboard if the Processor over heats and burns.
Since you are able to start the Notebook without any errors or Bluescreens, all the other hardware components should be fine.
Hope this helps...
Posted on Sep 15, 2008
Hp pavillion dv9000 power input jack lights up and power is getting to mother board but it wont power up
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 21, 2012 | HP Computers & Internet
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Hp pavillion dv2210us harddrive failure
sounds like it may have died try it in an external mount (on a different computer)
Aug 13, 2009 | Dell Latitude D600 Notebook
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
HP dv9830us intermitently working
its a common problem of hp pavillion. i'm the expert. chat me at fixya romsky79
May 31, 2009 | HP Pavilion dv2000t Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
