Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
FISHER PAYKEL DISH DRAWER U3 FAULT CODE - Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
  • BronwenAlach Sep 22, 2008
    We came home last week and the dishwasher was flashing LP. We think the cleaner may have opened it before the cycle was finished.
    We turned it off, then when we tried to use it over the weekend, the dishwasher always stopped after about 4 minutes, flashing U3. About three of the setting lights were also on red.
    We tried different settings but the same thing kept happening.
  • mobilstoke Nov 24, 2008
    My dishdraw, bottom draw runs for a short time and then stops and flashes u3. If I swap the computer from top draw to bottom draw it will then work o.k. How do I fix this fault.
  • 15 Answers
LP is a setting for Low pressure. To reset your pressure to HP, hold the Programme and Eco touch switches simultaneously for 5 seconds. Once the setup mode is entered a beep is emitted and
the LCD is red with ‘HP’ or 'LP' displayed. Push the Start/Pause button to alternate between HP and LP. and push the power button to exit.
Posted on Feb 09, 2009
  • makeitsoone Apr 05, 2011
    Do not have LCD display on model DD602. What should the light combination be?
Diswasher is alarming F1. Can solve this problem
Posted on Feb 28, 2009
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer works but bottom drawer shows code u3 and bottom drawer started leaking water before the u3 code showed up
U3 code generally relates to drain pump blocked. This could mean the water is not able to drain out. Leaking of water is not a good sign. Shows the vacuum seal is not working.
Clean the drawer door from inside and make sure the seal lining is sitting properly. Also the filter plate and the motor cavity needs cleaning. You will need to see the user guide on how to do this.
Nov 02, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
U3 code on fisher paykel dishdrawer how to reset?
This site tells you how to reset:
http://applianceguru.com/forum1/163.html
I have the same issue and will try this tonight to see if it helps.
Feb 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
U3 fault code
http://d.scribd.com/docs/1nt2h7ei2nuuw9vihz41.pdf
Jan 16, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
3,133 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
