Question about Beko Dishwashers
Dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens.
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
Dishwasher control panel problem?
what is your model number is then we can get started then
Jan 04, 2013 | Dishwashers
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Quiet series 300, Model # MDBS561AWS. Power to control panel comes on. (lights up), But will not start.
If you are able to select a wash program but Start does not function, then most likely the door switch is not making proper contact. Check the door switch item 4 in this diagram.
Sep 03, 2011 | Maytag MDBS561AWS Stainless Steel...
Dishwasher won't start. The Quick Rinse light is blinking on the front panel. I pressed every button but nothing happens.
The light blinking indicates that the program is ready to start but has not received the go signal from the Start / Stop b utton as the switch is probably faulty.
Try to reset the machine by disconnecting the mains power, waiting at least 10 seconds and then reconnecting. Try to start the machine in the normal way and if it still will not start then it means that the switck control is faulty or the control unit has a fault.
Yo will probably have to call a dishwasher technician to rectify the problem.
Jan 10, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Maytag Dishwasher Model: MDBTT59AW
My research indicates that this is a control board malfunction, but with so many different descriptions of failure, I am left confused.
You may reference the link below to help isolate your problem.
Sep 07, 2007 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher almost fixed but won't pump water
Could be the motor is stuck. This is a common problem in dishwashers. With the power turned off, open the front kick panel and turn the motor a couple of times by hand. Then turn on the power and run the drain cycle to see if the motor drains properly.
Aug 21, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
458 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
