Question about Jenn-Air Electric Double Oven
How do I lock bottom oven?
I'm trying to lock the bottom oven so my son can not crawl into it.  I can't figure out how to lock the oven when it is not in use.
    Sergeant:
  • 409 Answers
can you tell me the exact model # on your oven please?
Posted on Sep 14, 2008
I tried to auto clean bottom oven. Showed err
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 05, 2010 | KitchenAid KEBC208 Electric Double Oven
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Candy sprinter hobb all on L locked?
Ours started doing the same Displaying L on four hob displays. I figured to press the bottom right hob and the minus button at the same time should unlock it.
Thanks
Trev
Oct 07, 2009 | Candy Ovens
Lock for self cleaning cycle in the on position
unplug the stove, then force the mechanism back with a screwdriver
Jul 22, 2009 | Ovens
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Have bottom oven door on Whirlpool RBD245PRS0 problem
youll need to pull the door back off, and "spring load lock" the left hinge and try again, youll never getit back on if one side is not in locked position. itll be tricky, but there no way around it
Jan 25, 2009 | Whirlpool RBD245PR Oven
GE Profilt XL 44 Gas free-standing range
Even with a predictable wait or wading through a telephone tree, I would try their Appliance Parts division:
1-800-837-4905
Aug 03, 2008 | Ovens
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Nov 22, 2007 | Whirlpool GBD307PRS Stainless Steel...
Jenn-Air Electric Double Oven Logo
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
