HP LaserJet P2055d Printer Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp laserjet P2055d printer donot turn on. - HP LaserJet P2055d Printer
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 12, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
451153
Points
2591
Most of the cases, power supply goes bad, open check the input fuse, if its open check primary section of the power section, replace defective components.. if power supply good replace formatter..
5answers
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
How can print power point slide in hp laserjet P2055d?
why i can't print power point slide in laserjet P2055d?
Hp laserjet printer p2055d print blank pages what is the problem?
Probably a bad ink cartridge. Remove the cartridge and clean the face of it with alcohol to remove dried or clotted ink.
Dave W.
3helpful
I AM USING HP laserjet P2055d printer and its giving me an error saying "jam in output bin" What should i do because I cant see any jammed paper?
Hi
the last sensor on your printer it is stuck
check fro paper on it or if it is broken
Pls vote me to keep me alive
My printer prints out a blank page if im trying to print a pdf from adobe reader. its hp laserjet.
it sounds like your printer cannot translate the the graphics being sent from your computer.
It may be that one of your printer settings is not set correctly.
Or, it may be as simple a solution as updating your driver for your printer.
Try here for a driver for Laserjet P2055D:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3662055&taskId=135&prodTypeId=18972&prodSeriesId=3662052&lang=en&cc=us
If this is not your model, search for your specific model on this HP website.
Note there are also firmware upgrades for the P2055D printer.
Cheers,
Steve
10helpful
2answers
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
k24674
Grand Canyon Tech
Grand Canyon Tech
