Question about Motorola Radio Communications
2 way radios
Hi How do i identifie the 6 channels on my MOTOROLA RADIUS GM300.
It was given to me. No power leads or ant leads. So before i buy them. I would like to know if i want to put in it my boat. Which is the only use i have for it. Than you for your time.
douggie11
  • Douglas Sep 15, 2008
    Hi again, The MODEL NUMBER on the back of the radio is M33GMC09C2AA. I think this radio may have been in a boat at one time. altho ony six channels in a boat radio in AUSTRALIA is unusual.
    Thanks again douggie11
  • eradiostore
    eradiostore May 11, 2010
    If you would supply the model number of the radio, we could tell you what frequency band it is in. However, the only way to conclusively tell what frequency and/or PL code is programmed into each channel is to have a dealer "read out" the radio using Motorola software. The GM300 is a programmable radio and could be program to any frequency within the individual radio's range.
  • Motorola Master
  • 1,654 Answers
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Posted on Sep 15, 2008
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Does a motorola gm300 model number m43gmc29c2aa have ctcss or PL TONES capability's?
Yes, it seems to me that the GM300 radios did have tones as programming options. They were programmed by the dealer using radio service software (RSS) when the frequencies and other channel information were entered. Of course, Motorola discontinued the GM300 a long time ago, and they were wide-band radios, so you could not legally transmit with them anymore. However, you could find someone on eBay to program them receive-only with or without CTCSS (PL) tones and then you could simply listen to them.
Jun 24, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
How to change frequency on gm300
To my knowledge the GM 300 can be programmed only with a DOS based programing software. Start with the DOS, not from the windows
Mar 12, 2009 | Motorola GP300 Compatible 2 Way Radio...
Motorola GM300 Question
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Aug 23, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
Jul 05, 2008 | Motorola Talkabout FR50 (14 Channels)...
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
May 19, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Radio Communications Logo
304 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
