Question about Panasonic Toughbook CF-27 Notebook
No power the password i dont care about anymore, the laptop wont even turn on anymore. i have the ac cable plugged in but when i push the button it wont turn on
  • m3nameis Sep 14, 2008
    the ac is plugged into the notebook
    internal power supply???
  • 145 Answers
Take out the battery first then install a new hard drive like i did this will work
Posted on Dec 13, 2008
  • Panasonic Master
  • 5,568 Answers
Is the AC plugged directly into the notebook or is there an external power supply? If it is the latter, any multimeter would tell you if the external supply is still doing something.
If you have a meter (or a friend with one), don't get confused if the output if much higher than is stamped into the case since these are often only crudely or totally un-regulated with the bulk of the work being done inside the case where circuitry regulates power for the board with the computer on and the batteries under all conditions.
Posted on Sep 14, 2008
  • Steve Allison
    Steve Allison Sep 15, 2008
    'Fraid so; and it depends on the degree of integration whether you can replace it yourself.
    Normally, in the case of an integrated supply with few exceptions, the power supply will be physically separate from the logic circuitry for several reasons:
    - The switched mode power supply (SMPS) is 'noisy' from an electrical standpoint. They are fed directly from the AC line without any transformer between the wall and the first components, diodes. These rectify the incoming AC and typically produce ~ 170 volts of lumpy DC that is filtered with a couple of capacitors and then fed to a circuit that (kind of illogically) chops the DC into AC but at higher frequency; anywhere between 50,000 cycles (Hertz) and 200, 000 Hz.
    This higher frequency is coupled via a ferrite (not iron as for low frequncy) core to several windings that provide different levels of voltage and those are fed to . . . diodes again :-)
    That is filtered via capacitor and inductive filters that remove the high frequency ripple from the DC for use to various parts of the circuitry.
    The reason for this somewhat convoluted path is that for equivalent power capability, many of the components (in particular, the main power transformer) do not need the bulk required for processing 50-60 cycle AC into low DC voltages used in digital and analog devices.
    The fact that they use these high frequencies causes them to be sources of all kinds of 'static' way up into the megahertz range that could easily affect the low voltage circuits they service.
    - Secondly, because they deal with hundreds of volts, it wouldn't be good design practice to have them share a circuit board with low voltage components.
    If you are adventurous, you will have to carefully split the top and bottom halves of your case; these often have very few screws, some hidden under the access covers for memory on the bottom and may have some screws associated with various connectors for external devices.
    Once you are sure you have located and removed (these are tiny screws!) them all, the case-halfs are nearly always snapped together so even with no screws holding them. they will not often simply come apart.
    You will need a pry tool such as a putty knife (or very strong fingernails as I) to start the unsnapping; don't use something too narrow as you will damage the cheap plastic of most cases.
    Once you have the case open, touch any piece of sheet metal shield to eliminate any static voltage difference between you and the guts of the machine since many semiconductors die with fairly low static voltage discharges.
    After open, it shouldn't be tough to recognize the PS board since it will be the only one that is fitted to receive the AC cord and will have parts on it much larger physically than the logic (mother) board.
    This board may have a fuse on it but it may be soldered in place rather than in a holder.
    The fuses of today are, in most cases, not the glass or ceramic types in clips. They are often 'microfuses' that are socketed or soldered and are ~ 3/8" tall and ~ 1/4" in diameter and mostly black epoxy cased.
    The board (well most all of them) may have more than one part number on them; quite common is a bare board number, another for the assembled board and this could well be on a sticker since it seems no one gets it right the first time and a board may be altered several times during production and get revision numbers.
    Or, you could forget all of the above and either junk it or give it to a tech to repair.
    Good luck -
My power button is broken and my phone wont turn on
its a hardware problem from your power button and causing some shortages so your phone wont open up. if you know how to disassemble your iphone you can probably fix it but be careful if your going to disassemble it make sure you dont loose some parts and tear the flex cables :)
Feb 06, 2013 | Apple iPhone 4 Black Smartphone
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
Power
Look under the laptop. There should be button to push to the side(it has a lock picture). After pressing it the hard drive will come out( i dont know if it is a hard drive). After it comes out put it back again. It should help. It worked for me.
Aug 03, 2009 | Dell Computers & Internet
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
My laptop wont start
my suggection is that the element has gone so it would be cheaper for you to take it to the shop for repair.
May 13, 2008 | Toshiba Satellite A135-S2386 Notebook
Wont boot to start up windows
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays
Mar 29, 2008 | Computers & Internet
Tv just wont turn on
power supply fault it could be any component if not qualified dont risk taking a look inside, high voltage supply.
Oct 14, 2007 | Panasonic (LSSQ0372) Remote Control
Panasonic Toughbook CF-27 Notebook Logo
71 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
