Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi ws 65513
Eljavier0170@hotmail.com So I found out today that I too have the fast flashing led problem. is all I need to do is replace the 1000uf 16v caps in the on the DM power board? Will 25V size fit. thanks in advance.
  • pjmccli Sep 15, 2008
    LED Indications Conditions Probable Cause
    Off After AC is applied No Standby Power or TV μPC not running
    Fast Blink for 70 sec. After AC is applied Normal - DM μPC is booting up.
    Fast Blink for 70 sec. Each time TV is switched On Power Save Mode is activated
    Fast Blink (Doesn't stop) After AC is applied TV μPC is running, but DM failed to boot up
    Slow Blink Set is Off Normal - Timer is set for Auto Trun On
    so the above leads me to think that the problem is in the DM. And from what I have been reading/finding out that the caps have a high failure rate? Is that what you have seen/heard? Thus the need for the replacement of the caps... I also understand that higher Volts is ok if the size of the cap will fit.. do you have information that refutes that?
    Thanks in advance.
  • Mitsubishi Master
  • 19,396 Answers
You do not replace anything that youhave not tested first, and if you want to do it yourself you must have practice with soldering and using a multimeter.
Green led flashing fast is only telling you that you are in protect mode, and that there is a problem inside your tv. Most people on the internet do not have an idea of what they are talking about.
Regarding the 1000uf 16v, there are 7 of them (the blue caps), and they blow often because of problems with power board.
Test them, and replace them ONLY if you do not read continuity, or if they are evidently blown.
Do not even think to replace the 1000uf 16v with 25V unless you read this on a Mitsubishi service bulletin, or service manual, or you may end up damaging your TV.
If the Caps are ok, follow troubleshooting diagrams on service manual to test the rest of the TV.
Regards
Posted on Sep 14, 2008
  • 10,594 Answers
Yes, 1000UF 25v would be fine. just replace all capacitors in DM Board.
Need further help, let me know.
Regards,
  • Shahid Electronics
    Shahid Electronics Sep 14, 2008
    Download Training Manual TV here, might be helpful in tv repair process.
    Shahid Electronics Sep 15, 2008
    Please check my reply, Its ok if you use 1000UF 25V instead of 1000UF 16V capacitors.
    Just be careful while repairing tv and AC cord must be unplugged, take care of Main Capacitors in power supply as they store high voltage charge for several hours.
WS-65513
mike, give me an email address and I can send you a PDF!
Dec 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Manual and repair instructions for mitsubishi WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws 65513
The documents are on it's way. Good luck
Mar 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Where can I get four capacitors 1000mf / 25v High-Temp 105 degree
Dec 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
