Question about Dell Inspiron 1501 Notebook
I get pink spots on my laptop
This just started happening i started getting pink spots on my screen on random things like picture outlines would be pink and not really flashing but getting thicker and thinnner. is their a way to fix this? p.s it doesnt happen when the computer is off
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
This is known as bleeding in LCD .you can try to update video drivers or try to connect external monitor (any normal desktop monitor) and see if same thing happens on external monitor then most probably it is the video card if on external monitor works fine then it is issue with LCD .if system is in warranty then get in touch with dell support
Let me know if this helps
Regards
Posted on Sep 19, 2008
Compaq laptop, pink and green pixalted screen.
compaq day, endless posts... endless dead old PC's
who owns this old junk and why?
no LT stated, of the 1000s
no OS stated , XP?" what?
ever heard of photos, take a picture post it so folks can see reality?
all PCs break all do and often and LT vastly more often, its portable and that breaks them faster. x10.
what PC< we cant guess PC hear
LT ran at HP from 1984 to now. vast types, and compaq to.
simple tests.
1: ;runs ok with battery out , BINGO !!!! battery number 1 failure.
2: lent, lent packs vents overheats and CPu and GPU go NUTS.
all puters do this if not cleaned 1 time per year, all do. its called servicing the PC .
3: bad power pack of power is weak the electronics goes NUTS.
4: does the external VGA jack work to a external screen. yes/no.?
5: is this a 2008 Laptop with the GPU SOLDER BALL FAILURES?
next time post the PCs real model number.
or the service tag here is one random.
tag1-yurc2tkkgu0y15feq43cohvv-3-0_0.jpg this LT?
LOL 1984?
if I had any compaq relics' (most have a value of $20 or less)
id buy this.
see walmart see those great deals on pC that are good and supported?
be best,
http://pcdied.com/cheaper.html
Mar 19, 2017 | Compaq Computers & Internet
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
The screen on my hp pavilion dv7 is making weird dots and at times on the white parts it goes pink kind of like it's inverted, and it does it at random times, what's the problem and how can i fix it?
The first thing you should verify would be to check whether its a problem with the screen or the Graphics adapter. Connect the laptop to an external monitor and see if you still get the spots. Let me know what you found
Mar 27, 2011 | Computers & Internet
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Screen goes pink and green starting with a few pixels
Best thing to do, try a different known working monitor to hook up to the computer. If the screen works and doesn't change colors then you know its the original monitor that is bad.
If you hook up the known working monitor and the same problem happens then you know its the video card that is bad and the video card would have to be replaced.
Aug 23, 2009 | ASUS VW222U Monitor
Laptop screen goes blank at random times.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
Go to www.lcdparts.net for parts detail and installation
Feb 28, 2009 | Dell Computers & Internet
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Neon Pink outlines around bright images
two points one green and another pink one in the screen Panasonic PT-61LCX65
Jan 30, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Problems with digital array
Aloha, did you get this resolved?? I have the same problem as you. Did you get your fixed?? If so, any information would be awesome. Thanks, Ravehawaii@aol.com. Thanks Bryan
Jan 10, 2007 | Hitachi 50GX20B 50" Rear Projection...
Dell Inspiron 1501 Notebook Logo
469 people viewed this question
Alun Cox
