Question about Lanzar Car Audio & Video
I have 2 15inch lanzar vibe subs (vw15d) and i didnt get any deminsions to make a dual box for them
These are the specs of the speakers:
Overall Diameter: 15.8"
Mounting Diameter: 14.6"
Mounting Depth: 7.4"
Overall Depth: 8.08"
Posted on Jun 03, 2009
How to hook up a vw15d to a single amp
Run it mono. Depends on the amplifier and how many channels it has. Run your positive to one channel+ and your negative to a second channel-. Make sure your power is disconnected while hooking up amp wires.
Dec 10, 2013 | Lanzar VW15D Car Subwoofer
There are 4 connectors on each side of the speaker, how do i wire it so i can put the sub in the box so i can connect it to my amp?
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Dec 24, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
What is the correct amount of air space needed to make my lanzar vw15d hit the hardest?
I would love to help you. There is one place that will help you better than I can and will demonstrate what you will need. Go to the following link and read the information there. Good Luck.
http://www.bcae1.com/spboxnew2.htm
Mar 23, 2010 | Lanzar VW15D Car Subwoofer
I have a Lanzar Vibe 235 amp. the green power light is not coming on, but the red "protect" light is. how do i solve this problem??
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe-235-amp-green-power-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Mar 11, 2010 | Lanzar Vibe 235 Car Audio Amplifier
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
Wiring
In all reality, that amp is probably a bit small for those two subs. To maximize the power from the amp to the subs, make sure:
  • The dual voice coils of each sub are in parallel (+'s together, -'s together). This makes each sub 2 ohms.
  • Connect the subs in series (+ to -). This makes the combination of subs together 4 ohms.
  • Bridge the 2 channels of the amp to the subs in series (see above).
This will put somewhere between 150-200W to each sub.
Keep in mind, though, that depending on the music type and location in the vehicle, the type and size of the sub box is going to make almost as much difference as how much power is on the subs. Sealed boxes are usually small and have a nice flat response, but tend to need more power to sound louder. Ported and bandpass boxes are larger and aren't as flat of a response, but have nice loud peak at a certain frequency.
Let me know if you need any more help!
Mar 19, 2008 | Lanzar Vibe 218 Car Audio Amplifier
Hooking up a sub woofer
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
take a look there and it should give you everything you need and show you the different options for the different ohm loads. Remember... don't go below 4 ohms on those. Above is ok, below is not.
Jan 10, 2008 | Dual XINBP-210 Car Subwoofer
Car Audio & Video Logo
197 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
