Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire dishwasher water does not drain out
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi psnell,
I'm Harvey the Master Plumber.
Your problem is: water does not drain out
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. The pump is under and requires removing the d/w. The control is in the top of the door. You might consider utilizing the Repair Directory to find a repair man. If the d/w has some years on it you may compare the costs of repair verses replacement.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
I have a Frigidaire dishwasher model number FGBD2431KF purchased around 2009. Water is not pumping out.
Sc. Check the drain valve, remove the pump and test it. If it is not the pump then probably a relay or switch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dishwasher Diagnostic Repair Not draining Frigidaire Electrolux...
Dishwasher Not Draining Dishwasher Drain Pump Replacement Part 5304463777
Frigidaire Dishwasher Not Draining
May 08, 2016 | Frigidaire Washing Machines
Thank you for your inquiry, friend!
I see that you need assistance in draining the remaining water out of your Frigidaire dishwasher. It is normal for a little water to remain inside of your dishwasher. If it is more than two or three inches it could be a draining issue. I would check to make sure the drain hose is not clogged or restricted. You should also review the filter, which you can find under the bottom rack, to make sure that it is not clogged. If you have reviewed these steps and water still remains it could be a possible issue with your drain pump. I recommend having a professional technician out to perform repairs because this will require you to uninstall and disassemble your dishwasher. I hope this information is helpful. -Matt
Feb 27, 2015 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
Water not draining fully on dishwasher.FRIGIDAIRE model GLDB653AQ1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Jan 15, 2011 | Frigidaire Dishwashers
Brand new first time using it Frigidaire dishwasher not draining has water in the bottom. Model # FPHD2491KFO
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
Nov 23, 2010 | Frigidaire Professional Series 24 in....
Standing water at bottom of dishwasher. Make and model is Frigidaire Gallery
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Sep 01, 2010 | Frigidaire Dishwashers
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
96 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
