Question about Rainbow Vacuums
Rainbow vauccum D4C model
My vacuum throw out air with water instead of sucutioning., The motor is spinning clockwise. the separator spins the same way that is why is pushes the air out instead sucking it. Can you tel me what to do. Thanks
  • 4 more comments
  • maxromen Sep 18, 2008
    9/18/08
    I have not dismantled the motor unit, Ijust inspected the way it spins.I figured out the problem. The lower ball bearing is frozen. How do you remove the ball bearing and to dismantle the lower rainbow housing and inner baffle plate. I think the D4c fan inside the housing is also damaged.I am sure there is a tool to remove the bearing. Where can I possibly buy that tool. Thanks again
  • maxromen Sep 20, 2008
    I have not received any good solution to my rainbow D4C problem. How do you remove the bottom ball bearing to get access to baffle plate. I need to replace the rainbow lower housing. The ball bearing needs to be removed first. Do you need to use the bearing removal tool?, if so where can I buy it. vacuum supply center doesn't carry that tool. Anyone Please help
  • maxromen Sep 21, 2008
    9/21/08
    Can some expert tell me how to remove the ball bearing to be able to remove the rainbow D4C lower housing with inner baffle plate. Checking the manual is a good recommendation but I don't think it is good enough. Every vacuum manual has no schematic diagram of the motor assembly to troubleshoot it. In a repair manual, Yes there must be but unfortunately I dont have it, So, Can any Expert tell me how to removed it and again I have not received any good answereit there is a tool and where can I buy it if there is. Thanks again Max
    9/21/08
    Can some expert tell me how to remove the ball bearing to be able to remove the rainbow D4C lower housing with inner baffle plate. Checking the manual is a good recommendation but I don't think it is good enough. Every vacuum manual has no schematic diagram of the motor assembly to troubleshoot it. In a repair manual, Yes there must be but unfortunately I dont have it, So, Can any Expert tell me how to removed it and again I have not received any good answere if there is a tool and where can I buy it if there is. Thanks again Max
  • maxromen Sep 22, 2008
    9/22/08
    Thanks for the expert recommendation of Swami Nathan. I already searched that link long before I posted this problem to FixYa "Expert technical Support".That Vacuum Manual is for vacuum parts identification and for minor troubleshooting as you can find in all appliances. This is not a repair Manual for this rainbow model RD4C. Thanks anyway. Please give me a good technical support as what should you do if this is your non working vacuum
  • maxromen Sep 23, 2008
    11/22/08
    separator filter is not a problem. The problem is a the frozen ball bearing, and how to removed it Thanks anyway
    Master:
    Sergeant:
  • 449 Answers
H!!!
try to bring your vacum in the shopping tools
near you try to find the tool frozen ball bearing
well be removed and replaced
Posted on Sep 23, 2008
  • 2,794 Answers
Make sure there is no debri in the seperator filter. If it is cleaned, it will divert the water properly as long as it is filled up to the fill line.
Posted on Sep 22, 2008
    Sergeant:
  • 208 Answers
Hi max,
you stated that, "The lower ball bearing is frozen. How do you remove the ball bearing and to dismantle the lower rainbow housing and inner baffle plate. I think the D4c fan inside the housing is also damaged."
The complete manual for your vacuum cleaner is in http://www.zianet.com/alkone/pdf_text/rd4_en.pdf
I think this manual can help you a lot.
The parts for your Rainbow vacuum D4c model is readily available.
you can change the part which has been damaged.
And i searched the net but i cannot find you the information about the tool for fixing your vacuum. sorry max.
I am giving you the link where you can buy those parts and fix it.
http://www.totalvac.com/rainbowd4.htm
http://www.rowecraft.com/totalvac/parts-rainbow.php?offset=75
Thanx max,
Hope my info is useful.
Bye.
Take care.
Posted on Sep 21, 2008
    President:
  • 1,952 Answers
Check ur manual setting...vaccum cleaner...can do both the things..
Posted on Sep 20, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
When the vacuum cleaner is empty, clean air flows into the machine and out through the pores of the bag. However as soon as you start to use the machine the bag starts to fill with dust and debris. The bag acts as a filter and the machine starts to lose suction. This is because the pores of the bag begin to clog with the dust that the machine has picked up. This restricts the airflow which causes loss of suction power.
Other Bagless Systems Clog like Bags
  1. When the vacuum cleaner is new, clean air flows through the container and out through the filters.
  2. However as soon as you start to use the machine the container starts to fill with dust and debris. The filters clog, and the machine starts to lose suction.
  3. This is because the surface of the filter becomes blocked with dust, restricting the airflow which causes a loss of suction power.
Thanks for using Fixya
Good Luck
Posted on Sep 19, 2008
    Sergeant:
  • 399 Answers
The plastic locks which holds the motor while spinning are slightly cracked so it not able to **** and its throwing outside.replace the plastic locks.
for any further queries feel free to ask.
thanks
Posted on Sep 18, 2008
  • 1 more comment
  • masterexpert Sep 18, 2008
    the plastic locks which holds the motor while spinning are slightly cracked so it not able to **** and its throwing outside.replace the plastic locks.
    the motor is not been able to move in anticlockwise direction because of that.so it is not functioning properly.
  • masterexpert Sep 19, 2008
    u can buy neceassary tools and parts from the lnk given below:
  • 10,594 Answers
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
  • Shahid Electronics
    Shahid Electronics Sep 18, 2008
    Here is Store where you can buy required parts for your vacuum cleaner.
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
Fins are broken on gear above water canister Can it be fixed and what caused it to break?
This part is called the separator and it can break from a possible hard item getting picked up and hitting it. Do not run if any fins are broken out as this will allow the Rainbow to drawl water up into the motor and out the exhaust. The purpose of the separator is to throw the water back into the water pan and allow clean air to go through the motor and out the exhaust.
Nov 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
The rainbow e series is leaking water when running-I assume that I need a new seal? If so, what is a good website to order from
Clean your water separator. That is the thing that spins around in the water pan, that it attached to the motor. It is a bunch of slots around it. Like a strange fan of some sort. The nut holding it on is half ench. Use a tooth brush, if you do not have the separator brush wrench. It is stored rite there on the bottom of your vacuum, by the warter separator, in a little slot for it.
Ralph
Dec 26, 2010 | Rainbow Technologies D4 Bagless Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacs Will other D4 water bowls fit a D4A
Yes, but just the D4 variety, not D2,D3, or E
The main thing to remember about this great vacuum you have is to always dry out the bowl or at the very least keep the bowl separate from the vacuum (top). The D4 motor was and still is the biggest and best motor EVER put in a vacuum, but if you let the moisture sit on this motor by not drying the bowl then what will happen is the spring loaded carbon brushes that make contact with the motors armature will ever so slightly 'stick to the armature. Then when you go to turn the vacuum on the motor will not even have the needed chance to begin it's rotation.Electricity in a motor has to move it's counterparts or it will instantly short circuit. Now believe it or not, as powerful as this motor is, if it can't move it will short. Ironically, you can do one thing ritualistically each and every time you use you Rainbow so that what I just described will never happen:
Under the top part f the vacuum you will see a pot pie shaped thing with a nut in the center. This is the heart of the Rainbow and it is called the separator. Very simply grab it and give it a spin. That's it! Now you have done the one and only thing to be sure the motor is not going to stick. Yep it was that simple, but if I didn't explain it's importance you would never know why they quit making this great vacuum and instead make the latest and supposedly greatest 'brushless' model E2. Stupid in my opinion. All they had to do was put a message on the top somewhere saying, " Before operating, unplug 110V plug, flip top and spin separator by hand to be sure it is free"
Oct 07, 2009 | Vacuums
IT WILL NOT START - IT TRIES BUT DOES NOT TURN ON.
Unplug the vac and spin the acorn nut on the separator in the water reservoir. If it spins freely and this vac has run for a few years you may need a fresh set of motor brushes. Do not attempt to run the vac if the motor hums or makes a burning smell. Worn brushes are normal and can often be replaced in an older Rainbow/ Rexair
Sep 28, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
374 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
