Question about OKI C3200n Led Printer
Error 173 i have an error code number 173 what do i do
Jemhadar was right. I have to replace the drum. Thanks
Posted on Oct 28, 2008
  • 4 Answers
Your printer most likely needs a new drum. Check the page count. Are you close to 15000 pages, then it is time for a new drum....
Posted on Oct 27, 2008
3 Suggested Answers
SOURCE: Error code 173
Thanks, The cable was not plugged in right. Solved now.
Posted on Sep 22, 2007
flopez
  • 161 Answers
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
Fatal Error Code 173 - OKI 5100 copier
173 is a fuser upper roller low heat error.
Nov 19, 2008 | Office Equipment & Supplies
Error Code 173, 192, 163
May 22, 2008 | IBM ThinkPad 600X Notebook
Replacement remote control
Try the web site: http://remotes.com
Your TV remote is listed for $34.99 plus shipping. Just enter Mintek in the search box and click on your TV model number (DTV-173).
Good Luck.
Feb 06, 2008 | Mintek DTV-173 17 in. TV/DVD Combo
Error code 173
Sep 20, 2007 | OKI B4300 Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI C3200n Led Printer Logo
332 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
