Question about Electrolux Washing Machines
Electrolux Front Loader 7 Kg Error Message E20
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
From the manual E20W Problem with water draining
Solution from manual electrolux Front Loader 7 Kg
Posted on Feb 08, 2010
I have a Simpson ezi Top Loader 8 Kg what does a E20 error code mean
Lift the top by unscrewing the screws in the back or remove the back panel and there you will find a code and test sheet. Very easy to follow if you follow it to a T.
Jan 20, 2016 | Simpson Washing Machines
Simpson 8.5 kg Eziset stops after wash cycle with error message E20. Am pensioner and unable to move machine. Machine is approx 4 months old. an you assist with advice pls.
If it's only 4 months old it should still be under warranty. Contact the place you bought it from and explain your problem to them. They should repair it at no cost.
Sep 17, 2014 | Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
Simpson error code 5p
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
Feb 23, 2011 | Electrolux Washing Machines
Wont pump the water out
You will need to tip the machine on it's side and access bottom and rear panels. Then check the pump and drain screen and drain for clogs and loose parts.
May 11, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Aug 12, 2008 | Washing Machines
Washing Machines Logo
594 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
