Question about Compaq Computers & Internet
Crashed computer. \WINDOWS\system32\config\SYSTEM is corrupt or missing. We dont have the original setup cd-rom. All we have is a windows xp disk for a different computer. Is there anyway this can work?
  • mnoel33 Sep 17, 2008
    I cant get past the original error screen. Ive put the windows disk in but cant get it to run. I cant get the recovery consol or anything else. We dont have the original windows disk for this computer. We are using one from a laptop. What should I do?
    Sergeant:
  • 300 Answers
After looking at all these posts , I can't for the life of me figure out why nobody is listening to this person when they say they DO NOT HAVE THE ORIGINAL SETUP CDROM
Did anybody think to ask the person what Operating system was on the computer to begin with ?
If it was windows 98 , chances are XP is not going to do well on a system like that
if it's an XP machine , then I suggest NOT loading an XP disc that has already been ACTIVATED on another machine !
This person requires a RESTORE DISC from the company he got the computer from.
Or they have the option to buy an Operating System Disc appropreate to their computer.
Thank you
Az.
Posted on Sep 18, 2008
  • Compaq Master
  • 13,433 Answers
The real solution to this problem is to copy the contents of windows/repair to windows/repair/system32/config/system
you can do this with the xp setup cd, start up recovery console and copy the files. Or perform a repair installation from the xp cd.
    Sergeant:
  • 241 Answers
Hi You need to boot into Safe Mode F2 or F4 Then you need to see if this will allow you to go into the
windows desktop. Please understand this is not hard to do so ... this will get you started in the right direction OK/// Please let us know if you have the safe mode screen on and how far will this allow you to go>>>>>> please post
  • Jayson Brollini
    Jayson Brollini Sep 18, 2008
    The Cd can be booted as long as your BIOS is set for you too do this. that can be activated in the Install screen F2 so this is also a possibility but lets start off by having you insert that disc and see if it prompts you to the REPAIR Windows or does it not load at all? If it does not load then the BIOS may have the Boot/Load sequence not set for that DRIVE in may be on the HDD or the Floppy ..... OK but the Bios is very easy as long as you do not change any settings (But that too is easy to fix) Default Settings (RESET back To Default Settings etc.
  • Jayson Brollini
    If you still are having problems Please just add a comment OK
    Thank You
    Jayson
  • 6,487 Answers
Try this while booting up the computer press F2 or F5 so you can ccess the boot menu and then press F8 so you can access the advance menu then after that select Boot from Last KNown Good Configuration and hopefully that will make everything working again...
Hope that helps............................
  • Mark Gil
    Mark Gil Sep 18, 2008
    If you cannot still boot and do a recovery using the CD for your laptop, that will be a problem and you may need to reload the operating system for that.....
  • 2,794 Answers
Make sure that the boot order is set for cd as the first device.  Load your Windows CD up.  Then the restore options will load up on the screen.
  • Tim Babcock
    Tim Babcock Sep 18, 2008
    You set the boot order up by changing the BIOS settings by pressing the appropriate function key to get into the BIOS setup mode and look for the boot section.  Change the boot priority to CD first, Hard drive as second.  Save your setting and reboot.
    You will get a message to press any key to boot to cd.  Press any key and follow the instructions on the screen.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Yes absolutely. You can repair it this cd itself also. Click this link for more information....
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
good luck
thanks
Posted on Sep 17, 2008
    Master:
  • 726 Answers
Yes go to control panel then go to system maintenance then use system restore to fix windows
  • 2 more comments
  • chris07551 Sep 17, 2008
    that will take u back to the last time your computer was good wont loose any files ,fixes windows and cleans any corrupt files also download firefox internet that also cleans and protects
    yes it will work also on your pc but you will need the access code at the end for set up
    also if u use the cd you can take the option of repair dont do new installation it will wipe all your stuff
    do what i have said and you will be fine.. thankyou see ya
  • 4,472 Answers
Yes it can work. Have you put the cd in? Can you boot the computer into safe mode?
Thanks,
Lee
  • Lee A.
    Lee A. Sep 17, 2008
    Please don't request more assistance/reject my help until I have gotten all the information necassary to assist you properly. You can boot into safe mode and use system restore to roll back. If that doesn't work we can go from there. If you have a moment and find this solution helpful you can accept and rate the solution accordingly as I strive to provide fast, accurate and economical solutions.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 18, 2008
    You will need to hit f8 when the computer is booting up. What happens when you put the Windows XP disc in? Is this disc an official XP disc?(not a recovery disc). You may need to enter the bios and tell the bios to boot from CD drive first. This work is really the work for a professional. You can bring it into geek squad and have it repaired. If you have a moment to accept and rate my solution it would be appreciated as I strive to provide fast and accurate solutions.
    Thanks,
    Lee
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
Computer won't turn on it say's \WINDOWS\system32\config\SYSTEM---Windows could not start because the following is missing or corrupt: You can attempt to repair this file by starting Windows Setup using...
Borrow that CD-ROM from any friend who does have one -- you don't need to have your "original" disk.
Or, telephone eMachines, and order a replacement set of "System Restore" disks.
Probably $20, plus $20 for overnight-courier shipping.
Feb 19, 2011 | E-Machines eMachines Desktop PC
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Jan 24, 2009 | Microsoft Windows XP Home Edition
Crashed computer. \WINDOWS\system32\config\SYSTEM is corrupt or missing. We dont have the original setup cd-rom. All we have is a windows xp disk for a different computer. Is there anyway this can work? I...
you have a registry problem! that could be result of a hardware problem.. there is a good article of things you can try, it's usually suggested for you use the same xp cd that you use to install the os, otherwise is risky business using a different cd... you may want to find a cd that has the same service pack you have before starting... if you can't get that cd, read my suggestiong below
I strongly suggest the following:
first of all if possible, take your hard drive out, using and enclosure or another machine try to back up your data so it things go wrong or it's just taking too much time, you can just wipe out the hard drive and start fresh with a clean install, you may find it this to be the easiest and fastest way... back up your data regardless then start troubleshooting.
Sep 18, 2008 | Compaq Presario 5000 PC Desktop
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
