Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Phone app not working correctly
greggz on Sep 14, 2008
hi please could you help me. when i tap the phone icon. Phone loads up but does not let me tap on anything, after about 5 seconds it quits randomly. I can phone people, by tapping the contacts icon on the main screen but when i do phone people, the only way to end the call is by turning the phone off. I have restored the phone and i have held the home and on/off button simultaneously for ten seconds. It still didn't work. This is really starting to bug me. PLZ HELLP!!!!
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Jan 15, 2009
-   I have exactly the same problem - to a tee! Problem is that I have an unlocked phone so dont want to retore the operating system to factory default! Does anyone know why it happens?-   Gate123
Dec 27, 2008
-   hi please could you help me. when i tap the phone icon. Phoneloads up but does not let me tap on anything, after about 5 seconds itquits randomly. I can phone people, by tapping the contacts icon on themain screen but when i do phone people, the only way to end the call isby turning the phone off. I have restored the phone and i have held thehome and on/off button simultaneously for ten seconds. It still didn't work. This is really starting to bug me. PLZ HELLP!!!! -   ali_w_g
Dec 03, 2008
-   The 'Phone' application does not allow me to do anything but I can access it and after about 5 seconds it goes back out. -   Guest
Nov 16, 2008
-   Same problem. Jailbreaked iphone with 2.1 everything works fine but the phone app keeps crashing all the time. I can make call via contacts or any quick dial I want and receive call but I cannot use the phone app, or see recent or have the options while I'm calling... -   farnaus
Oct 07, 2008
-   Er.. NM.. It's Mobilephone.app .. if I rename that folder the issue gets so much worse.. Wonder if I can just steal a copy of this app from someone else?-   fixya867
Best Solution
posted on Sep 14, 2008
Helpful)
ginko
Rank: Guru  Apple ExpertApple Expert
Rating: 87%, 5319 votes
See the following suggestions from Apple:
1 Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
2 Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone following the steps outlined above.
3 To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If the 3 steps above did not solve the problem , then the Iphone is probably faulty , take it to a Apple repair shop, or call Apple service phone number listed on the user guide.
Comments:
Sep 14, 2008
4 Reset settings: Tap Settings > General > Reset > Reset All Settings Note: This will reset all settings. No data or media will be deleted.
5 If that does not resolve your issue, try erasing all content and settings.
Tap Settings > General > Reset > Erase All Contents and Settings
Note: This will delete all media and data. All settings will be reset as well.
6 Try restoring iPhone using the latest version of iTunes.
Connect iPhone. When it appears in the Source list, click on Restore in the Summary tab.
If the 6 steps above did not solve the problem , then the Iphone is probably faulty , take it to a Apple repair shop, or call Apple service phone number listed on the user guide.
Was this helpful?
Yes
No
Solution #2
posted on Jan 17, 2009
Very Helpful)
Gate123
Rank: Apprentice
Rating: 100%, 4 votes
If you have Kate installed - remove it. This solved the same problem that I was having
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Feb 15, 2009
Somewhat Helpful)
IrishiPhone
Rank: Master
Rating: 83%, 13 votes
gate123 if you just use the restore factory settings in the settings menu it wont relock the phone. If you do a full operating system restore from itunes it will relock your phone
Was this helpful?
Yes
No
Solution #4
posted on May 13, 2009
Not Rated)
asgder
Rank: Master
Rating: 78%, 9 votes
Hi Friends,
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Related Problems
It was in a case and worked for an hour after being dropped,...
I am going nutts considering its a new phone, but the screen...
I did all the settings for Tmobile and when I try to go on...
HI !  I have problem with pwned iPhone ! It is not...
Can you Help with these PDA problems?
screen suddenly magnified and is...
Solve
re-booting does not help, impossible to enter security code, unlock, answer calls texts etc because... (More)
my iphone hang it show itune n usb...
Solve
my iphone hang it show itune n usb logo.. help me plzzzzzzzzzzzz
my iphone wont charge/turn on/turn...
Solve
iphone stops at the screen with the apple logo and goes to a blue screen help me plz
6 Other Users Have The Same Problem - Continued
Comment by fixya867, posted on Oct 07, 2008
Exactly the same issue and I've noted that Phone.app is no longer in my applications directory??
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 684
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(330) 502-6853
Instead of lugging your computer into a shop and...
(601) 918-0222
I will connect to your Computer and repair the...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
