Question about Maytag MMV5207AAS Microwave Oven
Power outage - Hurricane Ike - is there a reset button?
We tried the fuse - it is fine
there is no power at all for anything -
Jenel
  • Anonymous Dec 06, 2008
    I think this is the same problem. I have a GE JES1384SF microwave. One day the power went out. Microwave was plugged into a grounded plug in wall, not on a surge protector. After power returned on in house, everything worked except this microwave (which was only 2 months old at the time, and is still under the 1 year warranty). It is totally dead. I want to take this to a GE service center in the Detroit area (not have them come out) but cannot find a place where I can walk in with the microwave. Any suggestions? Any advise on what may need fixing?
  • Maytag Master
  • 9,085 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
Whirlpool mivrowave W10292071A MH7140XF Microwave Oven
My whirlpool microwave hasn't worked sice powers outage. Is there usually a reset button or fuse, somewhere
Jan 03, 2013 | Whirlpool MH7140XF Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
I accidently ran it for a few minutes wih nothing in it. I turned it off and everyting seemed fine. Later I walked in kitchen and there is no light, power or anything.
I assume you checked the power cord and house power circuit breaker panel... possibly tripped unrelated to your running the microwave empty.
(the following is from http://www.kellerstudio.de/repairfaq/sam/micfaq.htm#mictotdo)
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
If those are not the problems, then the main fuse is the most likely suspect for a totally dead microwave.
Remember, while you can do some repairs on you microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
Oct 21, 2010 | GE Microwave Ovens
Had a power outage and microwave died. is there a fuse or reset button somewhere?
there is usully a fuse inside all microwaves. they are avalible at most hardware stores and home centers
Sep 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
After lightning strike & power outage digital display & oven not working. is there a fuse or reset button? or is the circuit board fried?
Start by investigating, open at the point where power cord goes in there is a fuse if it is o.k there is another smaller trans former powering the display board that normally uses thermo fuse, find out whether the thermo fuse is blown i hope this solves your problem
Aug 02, 2010 | Microwave Ovens
Microwave on the blink after power outage in the neighborhood
There may be a fuse either inside the bottom cover or the back cover.
May 30, 2008 | Hotpoint Microwave Ovens
Not working model # jvm1339bw 002
Check the main internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 30, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
Maytag MMV5207AAS Microwave Oven Logo
130 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
