Question about Whirlpool Dryers
Whirlpool Elec. dryer.. Model No.Leq9858lgo..Serial No. MM4802488..Problem...It over heats. We set it on air fluff and it keeps over heating. We have replaced, motor,temperature switch, to no avail...Advise on any service flashs... My e-mail.... laurel8410@yahoo.com
  • 156 Answers
SOURCE: sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Posted on Mar 19, 2008
  • 132 Answers
SOURCE: The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Posted on Mar 27, 2009
jsrock516
  • 5911 Answers
SOURCE: replaced element and dryer still won't heat
You replaced the heating element, but did you check the Thermal Cut-Out (TCO) or Hi Limit Thermostat? These two components work in conjunction to regulate the temperature of the heating circuits. In most dryer related heat problems, the TCO will fail before the heating element.
The TCO is located on the outside of the heater box at the end opposite the heating element leads. The Hi-Limit Thermostat is also located on the outside of the heater box, but is located adjacent to the heating element leads. Both these components should read 0 ohms with a multimeter if good. If either component is found to be defective, you must replace BOTH of them at the same time. Failure to do so may result in premature failure of any components you replace. Thats why these two parts are usually sold as a set. The part number is 279816 and can be purchased at any of the following websites:
searspartsdirect.om
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
You can view a diagram of these components using the helpful exploded view diagrams on the any of the first three websites I have listed. The last website only shows part illustrations. The TCO and High Limit Thermostat will be listed as items 6 and 15 respectively under the "Bulkhead' parts section. NOTE: Item 6 comes with item 15 when ordering.
Another thing to consider is the input voltage at the wall receptacle. Did you verify the voltage was correct? You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
Now if you determine the TCO is defective, it usually blows for a reason. It usually fails due to an overheat condition. This is commonly caused by clogged or poorly installed exhaust vent ducting. If you haven't inspected or cleaned the dryer interior, or external ducting recently, now would be a good time to do so before you replace any parts. If left in a poorly ventilated condition, a dryer will overheat to the point of failure. Which may potentially ruin any new parts you replace.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Oct 09, 2009
sclarke7
  • 222 Answers
SOURCE: DRUM NOT MOVING ON WHIRLPOOL ELEC DRYER
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Posted on Jan 07, 2010
  • 23 Answers
SOURCE: Whirlpool AWZ3518 vented dryer. The dryer will
Disconnect the vent in the rear and try again.... If it now works you have a blocked exhaust vent....If not, you might have a bad sensor..
Posted on Sep 02, 2010
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
The dryer appears to be overheating. The top of the dryer housing get hot while drying a load of cloths. More than normal. Checked dryer vent, lint catch (clean) and exhaust hose and all appears clear.
Excess lint can also cause a dryer to get too hot. Again, you should check the filter and the vent for lint. Clean them if needed. Another thing that could cause a dryer to get too hot is a bad blower. This would need to be replaced if damaged. You should also, never use white plastic vent. This can cause your dryer to overheat and also be a fire hazard.
If you are not already a repairman, there will be some problems that arise that you cannot fix. The idea is to know what to look for and to fix whatever problems you can. This way, you don't purchase a new one or call a repairman unless it's necessary. When making repairs, always unplug your clothes dryer for safety. If parts are needed, make sure you have your manufacturer and serial number with you before going shopping. This will help ensure that you buy the right parts and save you another trip to the store. Most of us are intimidated at the thought of dryer repair. Just keep in mind that a lot of common dryer problems are simple (excess lint) and can be fixed by anyoneIf the dryer heats when the Fabric Care/Temperature switch is set to AIR FLUFF (No Heat), check the following:
-HARNESS/CONNECTION
-HEATER RELAY
-FABRIC CARE SWITCH
-EVEN HEAT CONTROL
Procedure:
1. Perform the Fabric Care/Temperature Switch Test
2. Set the following configuration:
Door- must be closed
Fabric Care/Temperature switch- AIR FLUFF
Timer- TIMED DRY
3. Press the PUSH TO START switch
a. Check voltage on Heater Relay. If P3-1 to P3-2 is 0VDC, replace the Heater Relay
b. If P3-2 is 48VDC, replace the Even Heat control.
Dec 05, 2010 | Whirlpool WED8300S Dryer
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
MY DRYER KEEPS TRIPPING THE BREAKER WHEN I HAVE HEAT ON IT WILL RUN WITH AIR FLUFF ONLY I HAVE TESTED THE HEATING ELEMENT AND THERMOS
I know you said you checked the heating element but you check to see if it also shorted to ground,Also sometimes they will only short to the housing when hot and the element sags touching the housing and grounding out thes would be the first things to check
Aug 09, 2010 | Whirlpool LER5636P Electric Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
I have missplaced my manual, so I want to know how to get the heat opperating, its new. / I turn it on and it only blows cold air, what am I doing wrong??
!. Turn off the circuiot breaker to the dryer,then turn it back on.
2. Make sure it is set for a heat cycle and not air fluff.
Jan 01, 2010 | Whirlpool LER7646E Dryer
Hi, i have a homebrand dryer. Model: TD50-89S. Without asking first,my son transferred washing to dryer. Unfortunately, there was alot of white fluff all over washing and he assumed the dryer could take...
Your duct work is probably clogged with the fluff, which will not allow the air to flow though like it should. When that happens, the heat builds up on the cabinet and the heat sensor shuts down the heat. Its an easy fix, it this is the case. Just remove the duct from the dryer, clean it out, clean out the fluff from the dryer duct connection, then go outside and inspect the outside dryer vent for clogs. Make sure the flapper is working on the outside vent as well. Good luck!
Oct 26, 2009 | Whirlpool LER7646E Dryer
Good Afternoon,
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer model #len 2000pgo and my wash doesnt get dry but dryer gets warm ...not hot like it should. what could be wrong??? its electric
Your venting plays a huge part here.Do you want to be 100% sure about the vent ,ok,for just ONE load remove the vent hose from the dryer keep atleast 3 feet clear for the air to exit dryer.Now select TIMED dry cycle for 60 minutes.Start dryer and make sure your in a heat setting (not air fluff).The normal load should dry in 60 min,If it does than you now you have a block in the venting.
May 23, 2008 | Whirlpool Dryers
Dryers Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
