Question about Kenmore 22422 Top Load Washer
Kenmore 80 series will not drain the water
My washer will not drain.. what to do.. will go through all the cycles but when it gets to the rinse it stops and will not drain to go to spin cycle
  • ikardster Jan 12, 2009
    My washing machine will not totally drain all the water out of the tub. It also smells like rubber burning
  • Kenmore Master
  • 5,568 Answers
Two possibilities; Programmer has failed, belt or direct-drive pump has failed.
Listen to the machine during the transitional time when it would normally start to pump; if you hear mechanical noises from within, then the programmer is probably still working and trying to initiate pump action.
Turn off the water supply, detach the hoses (drop them into a pot to catch residual water), pull the machine out from the wall, maybe after some of the water is removed with a bucket, remove the few screws you find in the back whereby the majority will be around the edge of the machine with perhaps one or two somewhere in the middle. With good light, check for the remnants of a shredded belt. If not seen, then it is either intact or could be direct drive of the pump.
Replacing a defective pump isn't rocket science and can be done by anyone owning a few fairly standard tools.
If you got to Sears website ( http://www.sears.com ) and then to the parts department, enter your model number to obtain the illustrated parts breakdown for your machine. There you can get the part numbers of a belt or the pump assembly and, if you have no other source, you can even order them for shipment to your address.
If you can locate a Johnstone Supply outlet in your area ( http://www.johnstonesupply.com/corp/Default.aspx, they will almost surely have the part numbers you need at near-wholesale price and they do sell to us mortals too.
Posted on Sep 14, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
I have a kenmore 80 series washer that goes thru all the cycles except that it doesn't drain after rinsing and this is my serial and model number if you need it: mod20852990 ser4549516
does it drain after the wash cycle before therinse cycle? if not there are usually 2 belt on the bottom of the washer, one is for the aggitator the other for the water pump. check to see if the belt is still attached and also take the drain hose down to floor level to see if the water gravity feeds out, if it does not pour out then your pump would likely be clogged from lint.
Apr 24, 2012 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
Mar 12, 2009 | Kenmore Washing Machines
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
163 people viewed this question
Sal De
fordexpert
Robert Rankin
