Question about Disney Princess MCP DVD2050P DVD Player
Question mark in right hand corner no picture
  • ijijamielee May 14, 2009
    I have the same problem when i put the dvd in a question mark pops up in the right hand corner i don't think i hear any turning of the dvd
How can I check my purchases so that I can find my voucher?
Hi Anne
On a computer: Select "my vouchers" in the upper right-hand corner of the page.
On a mobile phone: Select 'vouchers' at the top right-hand corner of the screen.
In the iOS app: Select 'vouchers' at the bottom right-hand corner of the screen.
In the Android app: Select the menu button in the upper left-hand corner of the screen and select 'my vouchers'.
From the "my vouchers" page of your account, you can also sort your vouchers by expiration date -- this is a convenient way to see which ones you need to use soon or mark a voucher as "used" to remind yourself that you've already enjoyed it!
May 01, 2016 | Cell Phones
Where are my photos in instagram?
Tap the icon in the lower right hand corner that should have a picture of a person from the shoulders up, or a card with that picture inside it. Either way, lower right hand corner from the main screen.
May 20, 2015 | Apple iPhone 5c
How do I send a photo from album to friend ?
Go to Photos / press select (top right hand corner) / select the photo you want to send (a tick mark will appear on it) / select the box with an arrow pointing upward (top left hand corner) then select the method you wish to use to send it (message / Mail etc) then send it using this method in the normal way.
I hope this helps
Mar 13, 2015 | Apple iPad 2
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
Green numeral in upper right hand corner will not
There should be a button marked i,press this and it should disappear
Dec 08, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blank bluey grey screen with white mark in the right top hand corner when i turn on my nikon s200 pic, light has come on and the flash is working but i cant c what im taking as tthere is no picture on the...
Hi, if its taking pictures ok and you can see them on your computer it sounds very much like the screen is damaged, If you can post a picture of the screen I may be able to confirm.
Best of luck
Jun 08, 2008 | Cameras
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Disney Princess MCP DVD2050P DVD Player Logo
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
