Replaced new color cartridge Message is coming insert color cartrige
  • meer_zaman84 Sep 14, 2008
    printer. scanner. copier
    hp psc 750
  • 691 Answers
The cartridge you have installed is most likely faulty. Change it for another genuine HP item and see if the error goes. If the error clears, return the old full cart to the point of sale for a refund under warranty.
If the error remains, there is most likely a fault with the printer which can not easily be sorted by the user.
Posted on Sep 14, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
General Error message on a Epson Stylus NX100
Incase you have used a compatible cartridge , they may not work at times . Insert the old cartridge and check , if it prints ( even though partially ) . The problem could bein the cartrige or the fitting of the same .
Dec 20, 2012 | Epson Stylus NX100 Multifunction Printer...
Hp officejet j3500- refer to device documentation to troubleshoot
problem with any one of your cartrides. open the carridge door and renove color cartridge and close it.if it says insert left cartridge then it could be the problem with color cartrige.or the same error come then put the color cartridge and remove the block cartrige.if display says insert right cartridge then it could br the problem with black cartridge.try clesn the cartridge contacts & ink nozzles and put it back (use a soft cloth to clean the cotact)
Aug 04, 2011 | HP Office Equipment & Supplies
Ink cartrige problem
This is error is common after a cartridge is refilled, in most cases it's because of "bad refill" and we can also say "dead cartridge". If possible, Please try the cartridge on another printer or try your printer with another cartridge. (i hope you know what tri color mieans = the color cartridge). Make sure the cartridge is not overflowing or leaking. Clean if possible, and never touch the print head, if you ever did so there's no way to make it work again. Hope this helps. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
Receiving the message "Ink Catridge problem: ink cartridge appears to be missing or damaged". I've tried everything from cleaning cartridge holders to replacin cartridges. Nothing works and the printer...
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Nov 24, 2009 | HP Photosmart D7260 Printer
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Receiving a "Insert color cartridge" error message
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
Jun 19, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Ink
you have a defective color cartridge or contacts on the new color cartridge are dirty clean with micrifiber cloth moistened with rubbing alcohol and then try if this doesnt work you have a defective color cartridge
Dec 22, 2007 | Dell 924 All-in-One InkJet Printer
Cartridge Problems.
Go to Printer & Faxes locate your printer> Right Click go to properties and maintenance you can reset the ink counter. hat should solve the problem.
Dec 05, 2007 | Dell Photo 964 All-In-One InkJet Printer
k24674
jasbo
jasbo
