Question about Canon CanoScan 5000F Flatbed Scanner
CanoScan 5000F foggy glass
The glass plate seems to be "foggy" on the inside of the scanner. As a result, the pictures which are scanned are also "foggy." This is a relatively recent problem with the machine.
Is there any way of removing and cleaning the glass plate?
No problem.
1st step. Remove the lid. It just pulls out at the hinge end by lifting straight up, horizontal if you like. Where the two lid posts insert in the scanner body you will find 2 screws, undo them, no need to remove at this point, too hard. Rememeber you left them in there though.
2nd step. Around the 4 buttons at the control end is a striped trim panel that is the full width of the scanner. Locate the join between this trim and the light grey underside of the scanner body and just left and right of the COPY & EMAIL buttons, Using your fingernails lift with some gentle force. This edge will pop up. Note, the trim panel has 3 location tabs that insert under the grey border edge around the glass. So pop the front edge first and pull towards yourself.
3rd step. Once this trim is removed you will note 4 little grey plugs equally spaced under this area. remove the plugs and you will find 4 screws. Unscrew them, no need to remove, remember point above.
4th step. Time for CAUTION. You will be able to lift the upper part of the scanner up in which the glass is mounted. ***There is a lead with little play connected to the 4 buttons PCB which is attached to the upper panel. To ensure you don't damage it accidently when cleaning the glass you can remove the 2 screws attaching it to the upper panel.
5th step. See if you can wipe it, with a VERY SOFT LINT FREE cloth, without putting you finger on it somewhere......................
6th step. reassembly is the same in reverse
Posted on Sep 16, 2008
According to the Canon USA website, this "fog" is deliberately applied as an antiglare coating by the manufacturer. The website says that even though it may look uneven and patchy, this is normal and it should not be removed. I had this same question some time ago and Canon tech support said the same thing.
The disassembly instructions were spot on, though. Thanks! I used them to try to fix a jammed scan bar.
Posted on Nov 25, 2008
Need a Driver for CanoScan 5000/5000F Vista,have the disk,but dont seem to be able to get it.
I have managed to locate drivers for your computer. You can download the drivers for your Canon CanoScan 5000F Flatbed Scanner here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner error 15. no manual.
Click on the link below to download the software, drivers, and owners manual for the Canon CanoScan 5000F Scanner:
http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_5000f
Oct 18, 2010 | Canon CanoScan 5000F Flatbed Scanner
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
Toms
hello tomsz
you can get all from here at CanoScan 5000F
select your os and language and download to pc .
riz.
May 07, 2008 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed.
Make sure the scanner is unlocked. Lock switch is either on the bottom, or under the scanner lid near the hinges.
Apr 23, 2008 | Canon CanoScan 5000F Flatbed Scanner
Are there any other words along with the error?
Does the scanner make any noise when you attempt to scan?
If possible, try the scanner on another computer.
Was the scanner working before?
What OS are you using?
Download the delete driver application and uninstall the drivers. Also, download the most current drivers and reinstall. You should also download and install the most current version of Toolbox.
Apr 19, 2008 | Canon CanoScan 5000F Flatbed Scanner
Scanning Film
Have you used this scanner on Leopard already? I didn't think this scanner was supported.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=8053
Do a search on "Leopard". The CanoScan 5000F is not supported in this OS.
Apr 05, 2008 | Canon CanoScan 5000F Flatbed Scanner
After i scan a document, the image appear in black screen. Why?
uninstall the software from pc and turn off. then restart and re-install software.
Jun 01, 2007 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner Logo
710 people viewed this question
old marine
old marine
