I NEVER MADE A BACKUP COPY OF THE SOFTWARE THAT CAME WITH THIS COMPUTER RECOVERY DISC
What can i do
Posted on Sep 14, 2008
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
Sep 29, 2015 | NTI Computers & Internet
There is a colored line at the bottom and top of my screen and the fan is not properly working and it also shut down if i used multi tasks. What should I do? I'm miles away from where it bought....
Hi Veronica, Create a recovery disc if you have not yet created one.
Make backup copies of your valuable files, then try any of the following:
Restore system files from the latest restore point when your computer was working normally.
Uninstall software or software drivers which are not compatible with your computer, if you have installed such software or software drivers, or, restore the preinstalled software or software drivers to the originally factory condition.
Restore your data from the backup copy made with the Windows Complete PC Backup and Restore feature.
You cannot restore your files which you have changed or created after the backup.
If your computer still does not work properly, recover the computer system.
Another option, "after making a backup disk as above" is to use windows to reinstall all files back to factory settings.
Hope this helps.
Kind regards
David
Nov 19, 2017 | Sony VAIO VGN-CS320J Notebook
How to create backup disk in a netbook
  • In Control Panel, click System and Security (System and Security), and then click Backup and Restore (Backup and Restore).
  • In the left pane, click Create a system recovery disk (Create a system recovery disc);
  • Insert a blank CD in the DVD, and then click Create Disk (Create Disc).
  • The disc is created is a few seconds:
Jul 03, 2011 | Microsoft Windows 7 Ultimate for PC
How do you reset to factory settings on the gateway ZX4931-31e
Click on Start -> All Programs -> Scroll down to Gateway (or type Gateway in the line) -> click on Gateway Recovery Management -> click on rider "restore" -> click "Restore System to factory default".
May 05, 2011 | Gateway ZX493131e Notebook
What do I need to back up My toshiba satellite L455. Computers don't come with cd's or disks any more with purchase?
Since you have Win 7 Home Premium, start with making a System Repair disc. You just need a blank CD-R or DVD+/-R (DL is OK, but not an R/W disc). Click Start > Maintenance > Create a System Repair Disc. (This will save you from needing a OS install disc in the future)
Next you can use the Toshiba Recovery Media Creator to create a set of backup discs for the initial configuration of the computer. (Use DVDs for this to avoid needing lots of discs.) This lets you make one copy of the Media - no chance to update for new drivers or any other information.
You can save your files with the Backup and Restore (in the same Maintenance files as the System Repair disc). With Home Premium this only works with an locally attached external hard drive.
If you need a complete backup after this, you will need third party software. Some external drives come with the software. Norton Ghost, Paragon Backup and Recovery, and Acronis True Image will all do a full backup to CD, DVD or external drive; there are others.Most of these will make incremental updates as well. There are a few free packages but those don't have the features of the above (like recovering just one file if needed).
I hope this helps.
Jul 05, 2010 | Toshiba Satellite L455S5000 Notebook
Windows not loading
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 05, 2010 | Computers & Internet
I bought the game on my computer and was sent a backup disc. When my computer went to the shop it was erased and the back up disc is broken.
Get data recovery software and recover it from the drive. The only proper & free recovery software I know is Undelete My Files Pro. You can use it for 10 times before needing to register it.
Otherwise you can spend about $150 on something like Disk Recovery Wizard which works great.
Feb 21, 2010 | Computers & Internet
Wish to make a recovery disk
Toshiba usually ships laptops with recovery cd/dvd sets.
If you have captioned recovery set, make sure to make a backup copy.
If this series no has recovery cd/dvd, must be a hidden partition for recovery in the hard drive. For make a recovery disc find the sotware loaded in the laptop (must be there) and make a recovery disc set. Be aware that some manufacturers limit the use of this particular software (you only can make one cd/dvd recovery set).
In the worst scenario that the recovery partition is no present you must load Norton Ghost v14.0 and make a full backup to one external hard drive (USB) in order to recover te operative system, drivers and software in case of disaster.
I hope this help you to solve the problem.
Posted by MCampos
May 31, 2009 | Toshiba Satellite Pro L350-S1001X Notebook
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
Acer aspire one
Hi there..
I had the same problem, but i did not geth any help..So i did find the solution by my own... Maybe i can help you...
Because they tell us to open some windows programs, but i could not even open my windows, so how i can make a recovery???
So, my friend, if you want to recovery your laptop, you shuld start him, and when he start, you press simultaneously Alt and F10. Then you can make your recovery. And look in the BIOS that is enabled Disc to disc recovery
Regards
Jernej
Nov 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
