Question about Maytag CWG3100A Gas Single Oven
F9 error maytag super capasity advance cooking system oven. i had a power outage last ning oven came back on and lock up with a f 9 error. it will not cancel. it acted like it wanted me to use the self cleaning system so i did last night. it still will not allow me to open the door and oven is cooled off. i also un pluged the oven for several hours but error f 9 still comes back on.
  • 1 more comment
  • Anonymous Oct 06, 2008
    My Maytag Stand Alone oven displayed the F9 after pressing the bake button twice (by mistake). I unplugged it. seems to work now... we will see.
  • Anonymous Mar 17, 2014
    oven shuts off clock goes blank
    oven loses power shuts off
Hello what is the solution????????????
Posted on Nov 27, 2008
    Sergeant:
  • 409 Answers
can you tell me the model # on your stove please?
Posted on Sep 14, 2008
    Problem Solver:
  • 4 Answers
F9 means the door latch has a fault. Since mine has a manually opperated latch I just unpluged the micro switch on the latch. easily accessed by lifting the top of the stove off... be careful not to damage the gas lines to the burners... Now I can bake but not use the auto clean fiunction.
Posted on Nov 29, 2014
Thanks so much, I did what hanging man said, unplugged stove fur 2 mins plugged it back up, fave code and witching 1 min it unmatched! Again thanks from Memphis tenn
Posted on Aug 09, 2013
Maytag with F9 code Model number is MER5770AAQ.. thank you
Posted on Oct 06, 2008
    Problem Solver:
  • 3 Answers
Well... this worked for me. I also have the Maytag oven flashing F9 code. I unpluged it for 2 minutes plugged it back in works now. Make sure the plug is all the way in the receptical..( sometimes that causes a problem). Hope this helps.
I had the same problem a power outage and then the oven read F9
Posted on Sep 19, 2008
I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Maytag Ovens
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
We had a power outage and now the oven will not come on. cannot set clock etc.
Have you checked your breaker box? It could be that the breaker for the range popped to the off position. If the breaker is still on, try carefully unplugging the range, leaving it unplugged for a few minutes, then plugging it back in.
Dec 27, 2010 | Maytag 30 in. Electric Single Wall Oven...
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
I have a maytag electic flat top oven and I get a
this Fault code F 9 is door latch supervisory .. you need to ck door circuit or replace clock assembly . also called the e r c ) .. this will in most services turn out to be the clock . the clock tells the latch what to do and its doing it . but i would ck the latch first .this part is much less costley .. m.m.
Nov 20, 2009 | Maytag Ovens
Maytag advanced cooking system/the super capacity plus
My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
Jan 20, 2009 | Maytag Ovens
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Maytag CWG3100A Gas Single Oven Logo
1,354 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
