Question about GE Profile DPSB620GCWW Gas Dryer
Conversion from natural gas to LP
After converting our natural dryer to LP with the conversion kit we have noticed that there is a rumbling sound coming from behind the dryer. Do we have to change the pressure setting? If so, how do we do that? there was not instructions to do so and we cannot see where to do it
If you look on the regulator , you will see a flat head type brass screw, remove it and inside you will find another screw made out of plastic, screw in 8 times to compensate for the lp gas. by doing that you will increase the pressure.
Posted on Apr 28, 2009
There was no direction with the parts
Posted on Feb 18, 2009
Is it safe to convert my propane gas dryer to natural gas? How much will it cost?
Al you need to get is a natural gas conversion kit for your dryer. Use your model number and look up a list of spares for your machine. Go down the list till you get to the conversion kits and get the one from LP to Nat of course, something like this one.
May 02, 2011 | Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
GE Profile DPSB620GCWW Gas Dryer Logo
183 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
