Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell tank n tank assemble
Looking for how the tank is assembled, I need to find a doc that show how the inter bladder is assembled, the rubber seal has come off the plastic tank
    President:
  • 1,673 Answers
Just insert the bladder into the tank, at the bottom, the lip of the bladder, pull it thru the hole then reinstall the autoload receiver(3 Screws).
Posted on Sep 18, 2008
Why is my Bisssel deep cleaning shampooer not releasing the formula?
the tank is divided into two parts, a fresh tank water, thats the one that has a rubber bladder and a pick uptank that store the dirty floor is the hard plastic tank. the bladder sets inside of the . pretty simple, in general. owner manuals can generally be downloaded from the manufacturers website. For Bissell products go www.bissell.com
and search for product manuals. Save the cost of a repair bill and take the family to a nice dinner! Good job!
Aug 16, 2014 | Vacuums
Took inner bladder out now won't hold water
Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank.
If the black cap is missing you'll need to purchase a new one. Here's a quick link.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial
Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
My steam cleaner is leaking as soon as i put the clean water tank on machine
The most common reason for leakage is that the reservoir assembly has gone bad. If you look in the area behind the tank, you will see a rod that pushes down on a small round rubber seal when you squeeze the trigger. The assembly being pushed on is the reservoir, and the internal valve may be bad. This would require replacement of the assembly. ( Part # 43526016, msrp $6.49 ). Another possibility is that the seal that the tank sits on is worn or missing. There is a round black rubber seal that the tank sits on. There is a plastic pin in the middle which opens the tank outlet valve. I sometimes see this seal missing - usually because a child has pulled it off. If it is missing it must be replaced. ( Part # 38784060, msrp $1.29)
Feb 21, 2011 | Hoover SteamVac F5914-900 SpinScrub...
There is a spring and a silver ball that seals the water from running out of the clean water tank, it fell out and I do not know how it goes back in. Bissel 1720 little green plus green machine
if it is from the tank,,,bad news,,, you have to replace the tank as a unit. according to the picture I see is an assembly and gives no parts breakdown on it exept the complete tank. there is a cover on top of the solution tank and is possible it goes there. that you can replaced but spring-ball part dont show on graphics. update.... cover is no longer available and tank price is about $23.00 at sears website part# 603-1204.
Good luck to you.
Feb 07, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
My bissell proheat turbo 2x hand tools will dispense solution but not water.
  • Fixed it! The check valve on the bottom of the bladder wasn't going deep enough into the recepticle on the base of the unit; the valve wasn't opening, and the pump was sucking from a dead end. (It WOULD pull soap from the small tank, but not the main bladder reservoir.) I cut a 3/4" piece of a disposable ball-point pen cap, to ride over the rod in the center of the recepticle. Long enough to push the valve open, but short enough that the tank assembly sat down on the base. If the rod is too long, it will push the whole tank up, and break the vacuum seal at the forward edge. Evidently this thing was designed to a tight tolerance, and just a little aging/distortion of the plastic reservoir base was just enough to keep the valve from being pushed open!
  • Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    My bissell pro heat turbo 9300 ...the bladder is not emptying so the carpets can be rinsed
    There is a clog somewhere in your tank. Either in the bladder or somewhere in your tank. You can find replacement tanks here:
    Proheat Parts
    GoodVac.com
    800-775-6586
    Jan 13, 2011 | Bissell Vacuums
    I cant get it to ****
    This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
    http://www.bissell.com/images/UserGuides/9500_908.pdf
    Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
    Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
    Depending on the model yes:
    Google turned up several sites -
    http://www.svcvacuum.com/bissell/tanks.htm
    You can also look at Bissell www.bissell.com
    Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Rubber valve at bottom of blader tank
    It is called the (#69)auto load asm, part # 2107041. It would be wise to replace it, It will come as one piece. Is the bladder ok? You can call Bissell and maybe buy the part thru them or they can tell you where to go to get it(800) 237-7691 ) .
    Feb 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
    129 people viewed this question
    Top Bissell Vacuums Experts
    Roger Potts
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
