Question about Kenmore 22422 Top Load Washer
Kenmore elite oasis he washer
Control panel has gone dead
washer full of water and towels
cannot open door to empty
  • Anonymous Mar 12, 2014
    door would not open washer was still full of water
    Novelist:
    Champion:
  • 261 Answers
Lets start by pulling the plug on this machine and while your back there notice where the three screws are holding the console to the machine and remove them until the top comes off noticing how it latches front to back and the screws secure it. Now you will see on the right hand side a grey box, look for a white plug top side left with only two wires sitting by itself and unplug it. Then plug the machine back in and you should still have no power. Next the cable with blue wires connecting the console to the grey box needs to be unplugged. Now we will test that grey box as it supplies your console. The test is as this unplug power, unplug console( blue wires ) then the next step is to plug the white plug with the thick dual black wires in. You should hear it cycle through all the valves, door lock and bump the tub. If this works and after you plug in the console and no power, guess what? Need to replace the console. Ps the plug with the grey sheath by the console blue wires is your door lock:) Write back if you need any help.
Posted on Oct 21, 2008
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
What happen when A kenmore oasis he washer has no power. Is there A reset button
In them tech sheets is some info on what to do in case that puppy appears to be dead in the water. OASIS TECH SHEET
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis gas dryer
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Door will not open
if there is still water in it use a wet dry shop vac and attach it to the end of the drain hose.once the water is gone it should unlock the lid.then check for blockage.
turn the timer or cancel any kind of wash cycle then unplug the unit for a few minutes this should reset the control to unlock the lid
Apr 13, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Top loading washer door locked
check the panel for triped breakers - check the plug for the washer - the door latch usually release itself after fewhe latch minutes- if nothing works try to force lid open with a thin screwdriver from the side were the door latch is
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Robert Rankin
