Question about Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705
I turn my dishwasher on, the heat comes on but no water comes through, can you please advise???
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi greggyboy70,
I'm Harvey the master Plumber.
Your question is: you turn your dishwasher on, the heat comes on but no water comes through, can i please advise???
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Mar 21, 2008 | Dishwashers
Indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Nov 27, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
362 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
